"Restore" engine additive?
  • sturte30
    400hp and AWD....Droooool
    • 3392
    My 94 exploder is burning a bit of oil ~1 quart every 4000 miles. Does that Restore engine additive do anything it advertises? ie. help compression, decrease oil consumption, etc?
    "There is a fine line between a hobby and a mental illness"
  • taank
    • 10278
    your supposed to change your oil every 3000 and 1 quart is pretty normal
    Jake H.
    • sturte30
      • 3392
      I do every 4000 on my exploder since it is just a beater and I don't drive it hard. Now, my cobra on the other hand, I change every 3000 or less.
      • taank
        • 10278
        regardless of your logic 1 quart every 4000 isn't bad at all.....
        Jake H.
        • Pauly
          It's Gone!
          • Jun 2007
          • 2870
          would have to agree on a 94 loss of a quart is nothing between oil changes. My 92 with a 351 did that and 01 with a 5.4 uses about a 1/2 quart between changes. My past experiences with those type of additives is all they seem to thickin up the oil to make it burn less. Restore and the likes are very thick in viscosity. It didn't hurt any but didn't really notice any changes.
          • taank
            • 10278
            save your money and buy some nachos
            Jake H.
            • sturte30
              • 3392
              Are "High Mileage" oils worth it?
              • mg72
                All Hondas All the Time
                • 1955
                No. Just use the next heavier grade if you want a surefire way to reduce consumption.
                The Jimmy hat is off.
                  try that lucas oil additive that stuff is sweeet
                  • Pauly
                    It's Gone!
                    • Jun 2007
                    • 2870
                    Was just gonna suggest something like that. Go to a heavier oil or just do like we did in the old days check the oil and add when needed not that complicated. Oh yeah and I 2nd save your money and buy nachos.
                    • Pauly
                      It's Gone!
                      • Jun 2007
                      • 2870
                      one other other thing I switched to the mobil clean 5000 and for some reason it doesn't burn off as fast maybe use a 1/4 to 1/2 quart at most between changes. But I still change it at 3000 miles.
                      • off white
                        • 314
                        regular oil just isn't made to last 4000 miles
                          I used regular Valvoline in my Mustang and had an oil analysis done at 3,000 miles on it and they said it looked great and said to go to 4k for the next one. that brings me to my next point, YOU ARE WRONG.
                            I wouldn't bother with any of the additives or anything like that. 1 quart every 4,000 miles isn't bad at all.
                            • xcsboost
                              Got Oil Bitches
                              • 2810
                              who the fuck told u that jiffy lube in fargo?
