5 lug conversion
  • brian5809
    • 302
    5 lug conversion
    how much would it cost? what all would you need?and what yards/shops would have all the parts for a 5 lug conversion for a 93 to peice togeather cheaply.
    thanks
  • StangerJon
    esse jay
    • 16655
    disc or drum rear breaks?
    and which style? 13" cobra or stock gt?
    ford makes a rear drum 5 lug kit for pretty cheap, and then the fronts is all about finding cheap sn95 stuff.
      When I did mine with GT parts and drums in back
      300 for hub/spindle, calipers, hoses (you also won't need hoses but I have a 86 - 20bucks)
      180 for new shocks and struts (option unless you have a 86 like me)
      220(ish) for axles, drums, brake pads and rotors
      25 for rear end fluid
      10 for axles seals (just do them!)
      25 for balljoints.
      I would say that is ballpark + wheels of course...
      I pulled most of the stuff from johns auto... and now that I think of it that 300 was also including rear disc brake parts so -100 or so prolly)
      • brian5809
        • 302
        the rears would be drums.http://www.blueovalindustries.com/pr...blueoval.would you need more than that?or is that complete?
          I say do it right the first time. SN95 brakes all the way around. 94-98 spindles, 99+ front calipers, rear discs.
          • brian5809
            • 302
            this is going to sound stupid.doubt its even possible.but do they just have adapters that you can put on like wheels spacers that go from 4 lug to 5 lug?
              What would be the benefit of doing that? You still roll on stock shithole brakes. The whole point of a 5 lug convo is to get better brakes and better wheel selection.
              • brian5809
                • 302
                the point would be that my bro would sell me his bullits really cheap.so do they?
                • StangerJon
                  esse jay
                  • 16655
                  doubtful.
                  that kit appears that it should have everything you need.
                    so do they?
                    No.
                    • Roast'em
                      has posted this
                      • 5496
                      I heard you can just get 11'' brake rotors (from Napa) for a lincoln mark8 in front. Then 5 lug axles in back with a disc brake conversion.
                        buy the bullets and then do the conversion. the wheels will fit like shit probably since you will have to run a pretty thick spacer just to get enough leverage on the actual 4 lugs and then you have to put the wheel on and blah blah blah, i think it would look like crap with the 4 to 5lug spacer.
                        just do the upgrade and run some big brakes.
                        • Dave90GT
                          Looking for a 911 SC
                          • 3051
                          thanks
                          Just save yourself the hassle and buy the Front and Rear kits from Apple Valley Ford. Ford Racing Performance Parts makes kits for both. That's what I did on my old GT. Works great.
                          Dave
                            You can change to this but bullits won't fit over the snout of the rotor (where the bearing sits). You need the hub style for most newer wheels to fit properly.
                            I'm not sure what your are looking to do but I don't think I would mess around with rear discs unless you got a bit of money...because once you put on the rears (using those special 200 dollar brackets or welding the backing plates to the back of the flange) you have to mess with a new booster and proportioning setup...
                            I am going to do rear discs eventuall because I have all the parts. But for the mean time I'm happy. The 95 GT brakes I used greatly improved my stopping.
                            I wouldn't mess with spacers either...the tires would never fit with something like that on.
                              This information is incorrect. There are no special 200 dollar brackets or welding IF you do it right. Take 94-98 Mustang Axles, put them into your diff, and bolt up the disc brakes. No welding, and it's easy. Putting on a new booster, master cylinder and proportioning stuff is easy. Don't try to steer this guy from doing this right by taking the cheap and easy way out by using drum brakes.
