I have been installing an eibach pro kit on my fox. Currently doing front springs / struts. I have tried 2 different spring compressors, and have achieved a total of fail.
When I use the comp. tha goes inside the spring, (pulls down towards LCA) the spring will not meet the upper spring mount when I raise the control arm. It is out too far.
When I use a comp that mounts outside the spring, the comp. is in the way.
I have read that you don't need a comp. to put lowering springs into a fox. I have tried that too. There's NO WAY it will!! The LCA has to be so far down, that the bottom of the spring just pops out of the mount as I raise the LCA.
Can anyone advise me? I am pretty nervous around compressed springs, and a n00b.
Thanks
Cliffs: Look at me fail? Easy steps to install front springs in a fox?
I am also fully prepared to see several "you're doing it wrong" and "fail" pics. I deserve them
Thanks
