Originally posted by Notch
View Post
1990 Bronco - 351W swap...
negative ghost rider... do not touch the injector harness... ever! it is better for it to run off time then to mix and match the 02 signals, you will wash the cylinders down, compared to a rough idle. having the sequential timing off on the injectors doesn't matter much because once it is over 1200rpms the injector firing rate is high enough that it doesnt make a difference. but if you correct the firing order of the injectors, the o2 banks will be off. 4 cylinders will always be flooding and the other four will always run lean.rides:
working at home? give me a call...Originally posted by Joe M View PostRe read 5 posts up.
i AM home.
I am done @ 6:30. I will be heading right into the garage.rides:
Why can't you switch the injector plugs around like you would with the spark plugs when going from non HO to HO?Originally posted by kramer View Postnegative ghost rider... do not touch the injector harness... ever! it is better for it to run off time then to mix and match the 02 signals, you will wash the cylinders down, compared to a rough idle. having the sequential timing off on the injectors doesn't matter much because once it is over 1200rpms the injector firing rate is high enough that it doesnt make a difference. but if you correct the firing order of the injectors, the o2 banks will be off. 4 cylinders will always be flooding and the other four will always run lean.
o2 bank 1: 1234Originally posted by Notch View PostWhy can't you switch the injector plugs around like you would with the spark plugs when going from non HO to HO?
o2 bank 2: 5678
you switch the plugs then look at what happens...rides:
sence notch didnt get it the new order is
o2 bank 1: 1257
02 bank 2: 3648
if bank 1 goes lean it will try to flood bank 2 becouse it doesnt know the differnce...rides:
Makes sense. So what if you just use the HO computer? Wouldn't it end up having the injectors pinned out in the correct order for the 13726548 firing order?Originally posted by kramer View Postsence notch didnt get it the new order is
o2 bank 1: 1257
02 bank 2: 3648
sure that would work fine... you could even use the da1 mustang ecu and it is almost a direct bolt in...Originally posted by Notch View PostMakes sense. So what if you just use the HO computer? Wouldn't it end up having the injectors pinned out in the correct order for the 13726548 firing order?rides:
or you could do nothing... it will run fine with the non ho computer. it would just idle rough. that is the only noticeable difference.rides:
