solid blinker on
  • SicLinc98
    Sic One
    • Sep 2005
    • 3027
    solid blinker on
    In my 87 escort the right front blinker just stays solid when the lights are on, rear still works and its not the bulb. Any ideas? I believe it worked when I first got the car
  • SicLinc98
    Sic One
    • Sep 2005
    • 3027
    Apparently the blinker works just fine with the lights off so its only when the lights are on
    • Fosters
      Typical white person
      • 16014
      front bulb (or even rear, if any of them are dual beam) or the flasher blinker thingy in the fuse box. owner's manual will tell you which one it is.
        Flasher muther fuckin blinker thingy!
        • svonasek
          • 1641
          Its not the flasher. The flasher either works or it doesn't. If the lights flash without the headlights then the flasher is fine. Its either a wiring problem or a bad bulb/bulbs. Id bet on the bulb though
          • SicLinc98
            Sic One
            • Sep 2005
            • 3027
            Tried 3 bulbs, old and 2 new
            • svonasek
              • 1641
              either you have a bad ground by the light that doesn't flash or the turn signal/driving light wire are some how shorted together.
              One last thing...Are you positive you have the correct bulbs?
              • SicLinc98
                Sic One
                • Sep 2005
                • 3027
                I will check the wires when I get a chance.I believe when I pulled the light it did have wire crimps on it. Thanks
                Yes that's what it came up in the system as, it also has the offset nubs so it can only go in one way.
                • matejcekautoworks
                  • 569
                  i would think your shorting somewhere
                  Go Big or Go Home
                  got married, still broke lol
                  • OhMannClint
                    Hated by the DEViDOs'
                    • 6149
                    What do you need blinkers for?
                    Clint Ohmann
                    651-399-9534
                    High Pointe Realty
                    ClintOhmann@gmail.com
                    • Fosters
                      • 16014
                      It's an escort, not a BMW
                        Corroded socket?
                        • Max Power
                          • 13086
                          Brilliant.
                          • matejcekautoworks
                            • 569
                            Originally posted by Max Power View Post
                            Brilliant.
                            well i do what i can :fu2:
                            Go Big or Go Home
                            • SicLinc98
                              Sic One
                              • Sep 2005
                              • 3027
                              I need blinkers so when I'm transporting drugs or bitches I don't get busted cause a blinker duh. Ill just turn my lights off when I make a right turn der
