fuel pump questions
Originally posted by jjhirsch View Post
All things are needed, and you can purchase each part at you local auto parts store. There really isn't a way to test the pump as the fuel in your tank cools the actual pump. Sure you can hook it up to 12 volts and it should kick on, but even a weak pump will still run. Dropping the gas tank isn't that hard to do, just make the tank IS NOT full. Good Luck.
do like the juggys. I would like to see in wet white t-shirt.
or naked
thanksOriginally posted by StockerFox View PostAll things are needed, and you can purchase each part at you local auto parts store. There really isn't a way to test the pump as the fuel in your tank cools the actual pump. Sure you can hook it up to 12 volts and it should kick on, but even a weak pump will still run. Dropping the gas tank isn't that hard to do, just make the tank IS NOT full. Good Luck.
or naked
