Fox neutral/park safety switch- which wire
  • 289Notch
    Lowballer
    • 7340
    Trying to get the car to fire up.
    car was originally a 5-speed then a c4 now a TKO manual again.
    there is a round 4 wire plug that goes to the trans.
    anybody know what the color code is for the neutral safety switch wires? also what are the other 2 wires in the plug.
    The TKO has a 2 wire plug coming out of the rear and a post with 2 connections on the side more toward the front of the tranny. anybody know which is for reverse lights and what is the other one?
    for now I think I'm gonna either hook it up to start in neutral only if possible or have no safety switch at all.
    Thanks YO.
    Mustangless!
  • lark-o
    • 10489
    Thanks YO.
    the plug on the tail shaft is the neutral switch and the one in the middle is the reverse lights. there is 2 wires for the neutral switch, 2 wires for the reverse switch and there is 2 wires that go to the speedo gear thingy.
    • svonasek
      • 1641
      If the car was originally a 5 speed car then the harness from the 5 speed to the body connector should have had a jumper wire in it. The jumper is where you'd have to splice in the neutral safety switch.
        If that is the Silver Notch, it was never a C4 car. AOD..
          I dont know if ltd still has it... but I gave him the conversion pigtail for the 5 speed. looking at the harness plug with the clip to the top. I think the 2 pins on the left are the nuetral saftey and the 2 on the right are reverse... I might be backwards... grab a volt ohm meter and find which one has power when key is turned. and jump it to the pin below it...
          I have never had a tko so I cant help you there...
          • 289Notch
            Lowballer
            • 7340
            Yep.
            The 4 wire plug is the one that goes to the AOD tranny. The car is wired for an auto.
            Mustangless!
              Yep.
              flat plug? I dont know then... I was picturing the round plug that is on c4's
              • 289Notch
                Lowballer
                • 7340
                No it is a round 4 wire.
                Mustangless!
                • DNeinstadt
                  Administrator
                  • 12578
                  I think it's purple isn't it?
                    Yep.
                    Yuppers. And its a race car, why do you need neutral safty switch. Man up boy!
                    • 289Notch
                      Lowballer
                      • 7340
                      OH NOEZ this is a full street car with a mild 289.
                      and I don't need the safety switch. but I need to cross the right wires so the car will allow me to start it.
                      Mustangless!
                      • svonasek
                        • 1641
                        White/pink stripe and red/light blue are the color codes of the two wires at the connector the you're looking for
                        • 289Notch
                          Lowballer
                          • 7340
                          thanks. I pulled out the multimeter and tested an aod I had laying around. You are correct. the other 2 wires are the reverse lights trigger.
                          Mustangless!
                          • theduckylittle
                            Duck uber Alles
                            • 5435
                            It's the blue-red wire IIRC. You can jumper it inside of the car, it's near the hole where the shifter mounts.
                            -Duck
