Primer'D
  • Black87GT
    Keyboard Warrior
    • 996
    Primer'D
    Ok, i got my car sanded, cleaned, primered (first coat) today, and i was wondering if i should sand when its completely dry and apply another coat, or just let it be if its ok?
    Any advice?
    '87 Gt- (Black) Underdrive Pulleys, bbk long tubes, Weld Draglites (Big and Littles), 3:73 Gears, bbk o/r H-pipe, 2.5" Flowmaster 40s, Cobra Upper/Lower intake, pro 5.0 short throw, zoom stage 3 clutch and flywheel, No smog equip., Soon to have an Aluminum D/s
    '97 Explorer Sport - (Green) All Stock 4.0, Runs great (DD)
    http://www.cardomain.com/ride/2574854
  • taank
    • 10278
    did you read the directions? the second coat should be applied when paint is still tacky. now you have to wait 1-3 days to fully dry. pm orange 88 he is a body guy
    Jake H.
    • Black87GT
      Keyboard Warrior
      • 996
      Yes, but im not going to be home for a day or 2, thats why im asking... if it looks good, do i even need a second coat?
        2nd coat give you the ability to sand/buff out future imperfections.
          +1. With one coat there is a good chance of sanding right through to whatever is underneath. Wait and do another coat
            Isnt the second coat supposed to be High Build? not that i have a clue what the fuck i am talking about but i thought i remembered hearing that in a drunken stuppor one night.
            • lord of the bling
              wants a race driven street car
              • 1100
              At our shop we usually do 2-3 good coats of primer, let it completely cure and apply a guide coat. guide coats are usually black in color, then as you block out the primer the guide coat will show you all the imperfections in the body such as low spots and deep scratches. repeat process until all low spots and imperfections are taken care of.
              • Killer Capri
                Bumpin it up to 10L
                • 4968
                dont listen to this man..... he has no idea........23 hr paint job......
                after youve lived though mine, hell is just a summer home.
                • BOB_T
                  Kounty B Kustomz
                  • Dec 2006
                  • 788
                  You can kind of use what you have on there as a Guide coat .... Block it all out with 320 & it will reveal your highs & lows........
                  You can pay attention to them areas with fillers & such.... then proceed to spray on another 2 or 3 coats of primer afterwards ...... Block it out once more with 400 & you should have a nice & smooth surface to work with ............
                  351W into Fox needed:
                  7qt oil pan , Billet Dizzy/Ignition , 1 7/8'' headers for TFS R heads , adjustable Tubular rear suspension & parts , Roll cage , 8+ gallon fuel cel / lines, ect..
                  TFS R heads off of 420ci engine
