T-lok "S" spring bigger than original
  • Hack
    • 1415
    #16
    I've never put one in, but the other advice I've heard is to use a small hose clamp to compress the spring. Install the spring with the clamp and then cut the hose clamp to remove it from around the spring. I like this solution because it doesn't seem as likely to produce eye injuries as just using a big hammer.
    2017 Mustang GT PP
    1986 Porsche 944
    • bigblockpaul
      i live my life a quarter mile
      • 4137
      #17
      just put in a spool and let her ride..
        #18
        you wouldn't need to cut the hose clamp... just hold the spring in palce with a scredriver or extention and pull the hose clamp out with a pliers.
        • Gear Slammer
          Turbo Fox body
          • 861
          #19
          or just try my 5 second method . You may want to where a cup, face sheild, and knee cap protectors, but other than that.......
          506 RWHP/488 FTLBS Trickflow, On3 turbo, APS tune on 11 LBS of Boost!
