whats the best small block heads
  • xcsboost
    Got Oil Bitches
    • 2810
    i have a 347 in a thunderbird, will be spraying heavy, if not a another adder probably kenne bell...none the less who runs what heads, i have a set of 165 afr's which i think will be not enough and i normally run holley heads I.E. system max2 kit
    what is the better end heads
    IB LSX comment...
      if you are dead set on AFRs get the 185s, if not then pick up a set of TFS Wedge heads.
      • xcsboost
        Got Oil Bitches
        • 2810
        was going for the trick flow version of the holley kit but i have pieced it together
          windsor
            I'm no expert but to really give a recommendation someone is going to need all the specs on the complete combo. If you're looking to bolt something on out of the box an AFR 185 is a great choice but if you want to buy bare castings and fill them with some good parts there are some really good heads out there. I'm running a set of TFS "R"s on a 410 ci motor. Should know pretty soon how they do. They move a ton of air. Nick
            • Racin Repair
              You wish!
              • Mar 2005
              • 2166
              Scrap the twisted wedge heads, High Ports!! or 205's
              9.10@142 on DOTs thru the mufflers, back when I used to race...
                i personally have never liked the AFRs, besides the ever growing rocker mount issue and valve issue, ive heard of some cooling issues, and to top if off i noticed their flow numbers are skewed due to a header size that can be misleading. wedge or Rs would do nicely.
                  sorry misread we have good luck with canfields though
                    doh forgot about these...
                      yea they are pretty bad ass for the dollar
                      • xcsboost
                        Got Oil Bitches
                        • 2810
                        i had a old set of the rhs heads, i was thinking of going with them now that comp cams started them up agaiin, I know alot of people that run the dart/proline heads
                          thats funny i was originally going to go with Dart for a long time, but i changed my mind earlier this year. ever since they started making the dart pro 1's for sbf i have never actually met anyone running them.
                          • prostang92
                            keeper of the lost toys
                            • 4479
                            have a set of steel tfs high ports w/ titanuim retianers, stainless valves etc.... have like 2k miles on them $750.00 offer
                            chris
                            WWW.RACECARREVOLUTION.COM
                            WWW.TRANSPORT-GRAPHICS.COM
                            • c10
                              • Dec 2006
                              • 1521
                              I got some N352's.........
