Does any one know if --
  • Bmikkalson
    • 3333
    A 2000 saturn SOHC motor. can be made a DOHC motor? That is to say IO have a 2000 saturn DOHC that needs a motor. I can get a 2000 SOHC motor cheap. Is it possible to just switch heads??
    MR,POWERS
    "Well now you know. Cops break laws all the time, luckily for them they aren't held accountable for most of their infractions."
    New Generation Auto, CJ performance Package STAGE 2
  • Turbo302
    Impossible is only Underfunded
    • 1528
    I have a 00 DOHC Saturn motor you may be able to fix cheeply. What happened to your motor? This one was running when pulled, but had a lower end knock noise. I havent even pulled it apart, but suspect a rod journal or something along those lines. It never smoked and still ran well besides the knock.
    You may be able to salvage some of the parts and make one good motor between the two of them.
    It is just taking space in my shop and you could have it for $60.(head alone worth at least twice that)
    The motor is fairly complete with good head, all intake fuel injection/injectors, exh manifold, oil pan, etc... Good builder.
    Let me know...
    Tim
    turbowindsor@msn.com
    1988 5.0 Notchback
    100% Stock 302 Intake to Oil Pan as delivered from FORD Factory
    100% Stock Driveline (T5, Clutch, 3.08's, control arms etc...)
    100% Stock ECM/Tune ('88 California Mass air ECM)
    1 bolt on... Baby Precision TE44 TURBO
    Best time to date: 11.562 @ 123.37 1.892 60-ft BIR 9/19/08
    • Spiral
      Crayon Guy
      • 8157
      Sure, you'll need to swap over the head and timing chain cover, timing chain (I would recommend getting a new kit), and the obvious intake, exhaust, etc, etc.
      The big difference between the SOHC and DOHC on internals is that SOHC have dished pistons whereas the DOHC have relieved pistons. So there will be a difference in compression.
      Otherwise, pick up an engine, you have to be able to find one cheap, I beleive 98-02 are the same.
      2013 Raptor
      • Bmikkalson
        • 3333
        Let me know...
        Tim
        612-730-5374 cell
        How many miles on it? It sounds like I may just take it for the head.
        MR,POWERS
        • Turbo302
          • 1528
          I cant remember exactly, but I believe it was around 100,xxx--130,xxx.
          Let me know...
          Tim
          1988 5.0 Notchback
