Ford Trac-Lok
  • Gear Slammer
    Turbo Fox body
    • 861
    #16
    burning corn ROCKS!! gotta love it.....
    506 RWHP/488 FTLBS Trickflow, On3 turbo, APS tune on 11 LBS of Boost!
    • D3thM3tal
      IT Pro / Mechanic
      • 3665
      #17
      Yeah, it smells great, is moderatly cheap, damn clean, and is much better then burning wood.
      I bleed blue
        #18
        A real baller would have bought this.
        • D3thM3tal
          IT Pro / Mechanic
          • 3665
          #19
          Yeah, I know, but I just bought this for the race car.
          I bleed blue
          • ClOckwOrk
            wakawakawakawaka
            • 1341
            #20
            /clap
            98 contour SVT
            not stock.
            • D3thM3tal
              IT Pro / Mechanic
              • 3665
              #21
              hehe.. The CSVT is getting a full stereo with sound deadening on the doors and entire trunk next. I have to take turns, so after that the 4X4 gets somthing else...
              I bleed blue
              • D3thM3tal
                IT Pro / Mechanic
                • 3665
                #22
                Well I got it rebuilt Monday, ran into some minor problems, and some scary moments. Job would have gone really smooth if I didn't have that thick ass 4.56 ring gear in there... or the drippy snow all over the place. I'll post some pix of the project tomorow when I can pull them off the camera.
                I bleed blue
                • loads
                  Slow red ford mafia member
                  • 1962
                  #23
                  Originally posted by sc0tty8 View Post
                  I did a rebuild once, 2 beer is doing my next one when I get my clutches.
                  He doesn't know I am sliding him an f150 s spring though
                  Inside joke, or is an s-spring from an F-150 an upgrade?
                  :geeza: -Member of WCR Inc.
                  Originally posted by Nifty
                  Can you please refrain from using logic? You're going to start making liberals cry.
                  • sc0tty8
                    Raised by wolves
                    • 4134
                    #24
                    f150 s spring is larger, more pressure to keep it locked tigheter(less slip)
                    No sig for you.
                    • D3thM3tal
                      IT Pro / Mechanic
                      • 3665
                      #25
                      Ok, so here are the pictures. I'm glad I tore this apart when I did, this thing was in such bad shape, it was starting to grenade...
                      Yeah, the tab on the other side snapped clean off and was at the bottom of the case, this side was wedged into the spider gears...
                      Clean everything up after shimming, shimming some more, and shimming again to get a nice and tight fit.
                      Completion!
                      Oh, and HOR, the wear pattern on the gears couldnt be better! Its perfect on both sides.
                      I bleed blue
