Ford Trac-Lok
  • D3thM3tal
    IT Pro / Mechanic
    • 3665
    Ford Trac-Lok
    I'm rebuilding the factory Trac-Lok that came in my 8.8 this weekend. (When I did the gear swap we found out there wasn't much left to it)
    I've got the kit ordered, and it will arrive Friday, I'm wondering if I can put some extra friction plates in there if I compress the spring some more for a tighter L/S?
    Anybody ever done/tried this? I'm thinking I'll put the spring in a vice, compress it, grab it with a giant vise grips and try and put it in that way. I'm not sure if I'm going to do it in the axle or on the bench yet..
    Discuss-
    I bleed blue
  • Xtort
    • 6968
    Discuss-
    I had matts brother do something similar, he put in an extra spacer or two. He knows what he's doing so I guess maybe you want a spacer rather than and extra clutch plate.. Don't forget the friction modifyer or it'll suck
    http://youtu.be/GTQnarzmTOc
    • D3thM3tal
      IT Pro / Mechanic
      • 3665
      Ok, because there are clutch plates, and friction plates. I'll use extra friction plates. I've got 2 bottles of Ford Traction Additive, and I'm also getting one with the rebuild kit. I ordered some royal purple synthetic gear lube, and it says in the description that it already has the friction modifier in it, should I add the Ford stuff or leave it be?
      Oh wait- from their site
      All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary.
      I bleed blue
      • Xtort
        • 6968
        Yeah maybe those spacers are the friction plates, lol. As you can tell I payed someone to do it for me .
        • loads
          Slow red ford mafia member
          • 1962
          Post up how this ends up! My LS is practically dead, and I want to do this...
          :geeza: -Member of WCR Inc.
          Originally posted by Nifty
          Can you please refrain from using logic? You're going to start making liberals cry.
          • D3thM3tal
            IT Pro / Mechanic
            • 3665
            Yeah, no problem. I'll take some pix, I like to take pix of the projects I do. Should be a fairly straighforward operation. Put truck on jackstands - Pull rear tires and drum covers - Crack open the case - Clean it out - Pull retainer bolt outa the 5/8" center pin, remove pin - push axles in, remove c-clips - yank out t-lok spring and carefully remove clutches & shims (remembering order) reinstall in reverse order. I'm wondering if I should soak the clutches in friction modifier before instaltion, I've heard of people doing that, but I'm unsure on the why..
            I bleed blue
            • HARD ON RUBBER
              The Original 5.0
              • 1157
              The kit comes with shims to properly adjust the clutch pack preload. The limiting factory to how tight you can shim it is limited by the cross pin. The cross pin has to fit between the two ends of the axle shaft. You can check clutch pack wear just by jacking up one rear wheel and pushing in and out on the wheel. On a properly adjusted clutch pack the wheel wont have any end play.
              Pull the diff from the veh and mount in vice. Pull out old clutch and toss. Soak the new clutches overnight in friction modifier. Re-use old shims and reassemble. Use one of the trucks axle and slid into diff while on the bench.Install c-clip. Can you get the cross pin in? If not, reduce shim. If you can, Measure gap between end of axle and crosspin and add that amount to shim. And if you are looking for a good wrestling match. Add a little more to that. Just remember, If you add to much you will never get the spider gears in or the crosspin in. You might get the spider gears in after a lot of wrestling to find out the crosspin wont go. Good luck.
              1993 Mustang GT, Cobra intake, F cam, 42s, Pro-m 80, 70mm TB, AFR 165s, MAC shorties, MAC H-pipe, Flowmaster 50s, AEM wideband, 3.73s, Centerforce DF clutch, G-Force T5, NOVI 1000, TWEECER custom tune by EFI Performance www.EFIPERFORMANCE.net Dyno'ed at MAPerformance 435rwhp 420tq. True story.
              Vice Prez WCR
              • Gear Slammer
                Turbo Fox body
                • 861
                I rebuilt mine this past spring. I went with one extra friction disc per side, and one less steel disc. It worked out great. Before I would hit it around corners and the inside rear would start to spin until I was going strait, then both would hook.
                Now when you get on it they either both go or nothing. I can definitely feel it backing out of my driveway. Its tight and wants to go strait.
                I didn't have any trouble with the s-spring clip. I just beat it in with a big rubber mallet. Adding the extra frictions won't really change that though, just your shims thickness. I had the most fun with getting the spider gears turned back in. They got really tight.
                506 RWHP/488 FTLBS Trickflow, On3 turbo, APS tune on 11 LBS of Boost!
                • D3thM3tal
                  IT Pro / Mechanic
                  • 3665
                  Oh, boy I'm glad you posted, lol, as my truck sits on the ground, you can grab the bed and shake it side-to-side and it moves a good 1/4-1/2 inch.
                  Crap, I forgot that I've gota pull the spider gears out So if I remember correctly, the shims sit behind the spider gears, and the clutches have a tab on them that locks them in place, and the shims are splined to the axle without a tab. I put the clutches in, spin the spiders in place, insert axle & c-clip and try and install the center pin. I take it the center pin should barley fin in there when the clutches are properly adjusted? That makes me realize how damn sloppy it was when we did the gear swap! This is going to be fun, being we barley got that pin in with that large 4.56 on it..
                  I bleed blue
                  • HARD ON RUBBER
                    The Original 5.0
                    • 1157
                    It's not a daily driver. SPOOL ftw
                    Vice Prez WCR
                    • Gear Slammer
                      Turbo Fox body
                      • 861
                      you got it!! rock and roll
                      • D3thM3tal
                        IT Pro / Mechanic
                        • 3665
                        Hehe.. I drive it to work when it snows, we fill it full of corn to heat the house, we pull out the dock or fishhouse with it. Its a util vechile until I put some Interco rubber under it, then those tires will have to come off to see the highway. A spool would be cool, but selectable locker would rock!
                        I bleed blue
                        • Turbo302
                          • 1528
                          110% correct
                          If you dont mind the rear a little chattery, I'd leave the friction modifier out. All that stuff does, is make the clutches slide across each other easier (slip). I'd rather have a chattery locked diff than a peg legged spinner
                          Tim
                          1988 5.0 Notchback
                          • Chrm97PI
                            268ponies with more onthe way
                            • 3413
                            be sure you soak all the frictions in modifier for 15 mins before you install them in the diff. if you dont you could end up smoking them b/c they wont be lubed when you take it out for your first drive on the setup. this process is a MUST!
                            • sc0tty8
                              Raised by wolves
                              • 4134
                              I did a rebuild once, 2 beer is doing my next one when I get my clutches.
                              He doesn't know I am sliding him an f150 s spring though
                              No sig for you.
