Backfire 302 EFI
    Backfire 302 EFI
    i adjusted the timing, now i have a nice backfire, but it runs awesome. 10 degrees BTDC
    12 BTDC was the magic number. BADASS! i checked my marker and it was loose so i was round 8-9 degrees BTDC i timed it out to 12 and threw some race gas in :X
      You shouldn't need race gas for 12*. I ran 12* and regular 87 on my 5.0 without any pinging.
        it shouldn't be backfiring at 8 or 9 degrees, you did something wrong. and racegas on a stock engine is stupid.
          smells so pretty though what do you suggest caused the backfiring then? i have no clue what the hell's done to this thing.
            • sc0tty8
              Raised by wolves
              • 4134
              Are the wires in the correct firing order on the cap?
              No sig for you.
                from what i've read in the book, and looking at the wires on the notch at BWW's they look to be right.
                  And if LEADED wrecks your O2'SSSSSSSSSS!
                  • mg72
                    All Hondas All the Time
                    • 1955
                    And plugs cats. Run premium if you are running 12 degrees initial, especially in the cool fall air.
                    The Jimmy hat is off.
                      How's the fuel filter? Maf sensor clean? Have you checked to see if there is any CE codes?
                        codes are clean, it's unleaded, above ground. im starting to think it might be sniffers, just kind of getting the basics figured out but, by winter it wont even matter what's going on with this motor :x
                        • SicLinc98
                          Sic One
                          • Sep 2005
                          • 3027
                          My car was backfiring and sounded like a shot gun maybe louder, we adjusted the timing and the thing runs beautiful, Pulls hard. Also my backfireing stoped so it could have very well of been the timing.
                            yea, that's what it was doing on startup, send a shotgun sounding BANG! but it would idle and run fine top end, im slowly putting more timing at it, seems to be helping. no pings and i have widebands, not the 2 wire analogs. i have high octane in there so i can do road tests instead of reving it up, i have a bad rep with the police in my neighborhood.
                            • SicLinc98
                              Sic One
                              • Sep 2005
                              • 3027
                              yea I need a wideband. I got the 2 wire digital read out, That doesnt work anyway....... What kind do you have and how you like it?
