24 lb in a speed density?
  • 87lxmustang
    NA rocks!!
    • Nov 2003
    • 210
    I.ve been kicking this around for a while about trying 24lb
    injectors in my speed density combo. Like I said in my last thread,
    my air/fuel ratio was spot on at 12.5/1 on the dyno,but I,m
    running 52psi fuel pressure on the 19lb'ers. Would it be possible
    to install 24's and cut back the fuel pressure?? I know my computer reads airflow on pre programed perimeters so the injector pulse width is set. But it makes sense that it could be dialed in with fuel pressure because I have to be close to the limit of the19's. I'm installing a typhoon intake in place of my ported stock lower and comp box upper and i'm anticipating more air flow (hopefully) and i'm not sure how far I can push the fuel pressure on the 19's. Has anyone tried this or know of anyone
    who has?? The driveability is great now and it gets about 23mpg
    on the highway and runs 12.70's at the track.
    Any info would be great
    I.m currently running out of the box TW heads-70mm throttlebody
    190lph fuel pump and the usual bolt ons with 3.55's out back.
    87LX hatch 12.635@109.21 Speed Density
    12.259@112.41 Mass air and Stage 1 cam
    311RWH 326 RWT ( 5-1-06) NA
    347 CI 370 RWH 374 RWT (9-1-10) NA
  • theduckylittle
    Duck uber Alles
    • 5435
    The should work out fine. My computer works on about the same principle and swapping up to 42 lbr's doesn't really effect much so long as you dial back the fuel pressure.
    -Duck
    1992 Mazda MX3: L3 100 BigYmp.
    • 87lxmustang
      NA rocks!!
      • Nov 2003
      • 210
      Duck,
      I,m not familiar with what your running.Svo turbo?
      Speed density?? What size injectors were stock?
      Tim
      • theduckylittle
        Duck uber Alles
        • 5435
        Originally posted by 87lxmustang
        Duck,
        Tim
        It's a 2.3 SVO Turbo engine. (More or less.)
        The computer is a Vane-air Metering type that's really quite stupid for various reasons. In any case, factory injectors are 35 lbrs. (Low Impedence) but both a speed density and a VAM style make the same assumptions about fuel pressure and injector size. So long as you provide approximately the same amount of fuel per injection it really don't care what injector you've installed.
        It only really becomes problematic when you start installing injectors that are so large that the car won't idle properly.
        -Duck
        • Macs Stang
          Dale Jr.
          • 18269
          Adjusting the Fuel pressure with the 24's would probably help like we were talking about today. Did you also adjust your ignition timing?
          I know that Tim was asking if you could use a Tweecer on a speed density car, is that possible? I am sure it would be, my guess is that if you choose to stay with speed density then you would have to shut off the mass air meter in the program. Not totaly sure, but I am certain that some people will chime in and answer the question correctly.
          I make horse powerz
          • 87lxmustang
            NA rocks!!
            • Nov 2003
            • 210
            Yes, i've played with the ignition timing. Currently i'm getting
            away with 18 degrees of timing running 93 octane pump gas
            with no problems. My 285hp dyno run was with 15 degrees
            timing but my 12.79@109.9 was with 18 degrees,short belt and
            fan removed,on drag radials.
            • theduckylittle
              Duck uber Alles
              • 5435
              twEECer is for MAF only vehicles. However, there is a version of the FMS (the old school piggy backer) that runs with it (if I remember correctly). I've heard that helps. So long as you're not changing the vacuum characteristics of the car there really shouldn't be any problems.
              -Duck
              • wiplash
                2014 TT/GT
                • 3479
                There's a couple of guys running the tweecer on speed density cars, seems to be working pretty well for them too.
                "I'm getting really tired of the turbo whistle"
                -No one ever
