I.ve been kicking this around for a while about trying 24lb
injectors in my speed density combo. Like I said in my last thread,
my air/fuel ratio was spot on at 12.5/1 on the dyno,but I,m
running 52psi fuel pressure on the 19lb'ers. Would it be possible
to install 24's and cut back the fuel pressure?? I know my computer reads airflow on pre programed perimeters so the injector pulse width is set. But it makes sense that it could be dialed in with fuel pressure because I have to be close to the limit of the19's. I'm installing a typhoon intake in place of my ported stock lower and comp box upper and i'm anticipating more air flow (hopefully) and i'm not sure how far I can push the fuel pressure on the 19's. Has anyone tried this or know of anyone
who has?? The driveability is great now and it gets about 23mpg
on the highway and runs 12.70's at the track.
Any info would be great
I.m currently running out of the box TW heads-70mm throttlebody
190lph fuel pump and the usual bolt ons with 3.55's out back.
twEECer is for MAF only vehicles. However, there is a version of the FMS (the old school piggy backer) that runs with it (if I remember correctly). I've heard that helps. So long as you're not changing the vacuum characteristics of the car there really shouldn't be any problems.
