Which Holley?
    Which Holley?
    Ok im trying to figure out which one of the 3 Holley's i got should actually be sitting on my intake.... 600v, 600dp, or a 750v ? i have the 600v on right now but i know its about due for a rebuild/cleaning, but should it really go back on?
    take a look at the vbgarage if you are wondering about the setup...
  • 86convert
    • 530
    I would go with the 650 dp that will give you a little room for mods. I think a 600 should work if it is tuned right.
    • Video_Master
      Kickin it Hybrid Style
      • 10524
      what is the engine right now? What mods do you have? What exhaust setup do you have?
      These are all questions we need to know to help you out.
        thats why i said to check the vbgarage about what was in the car i just didnt have time when i posted to type it all down....heehee
        is this better?
        5spd Florida Highway Patrol Interceptor Converted to Carb
        Engine:
        Bone Stock 88 5.0 HO
        1.6 Roller Rockers
        Custom Tall Billet Valve Covers
        Cloyes Timing Chain
        Moroso Solid Steel Mounts
        Fuel and Induction:
        Edlebrock RPM Intake
        Holley 600 Vaccum
        Holley Red Pump
        85 Gas Tank
        4" Cowl Fiberglass Hood
        Electrical and Ignition:
        MSD Digital 6 Ignition Box
        MSD Billet Distributer
        MSD Blaster 2 Coil
        Gear Reduction Starter
        Taylor Wires
        Moroso Cut-off Switch
        Battery Relocated to trunk
        5" Sport-Comp Monster Tach w/light
        2 5/8" Sport-Comp Water Temp
        2 5/8" Sport-Comp Oil Pressure
        Exhaust:
        1 5/8" BBK Longtubes
        2 1/5" Matching BBK Offroad H-Pipe
        3" Flowmaster Mufflers
        Drivetrain:
        3.73 Gears
        Weld Draglites
        Interior:
        85 Bucket Seats
        85 Steering Wheel
        Transmission:
        T-5
        • Video_Master
          • 10524
          well I would say the 600v if the right one for now. Once you get C/H/I I would upgrade to like a 650 double pumper. That should be good until you do something else drastic. I have a 650 vacuum secondaries and that is sufficient right now. I will be going to a 750 or possibly an 850 depending on what parts I get at the same time.
          • Turbo302
            • 1528
            Go with the 650DP you wont regret it. Probably want to get it on a chassis dyno or get a wideband so you can tailor the primary and seconday jets to your combo. Eaiser than reading tons of plugs
            Tim
            1988 5.0 Notchback
            • Mustangmatt
              The bobs...
              • 10806
              im with him
                ok i guess im gonna rebuild the 600dp then... should i go with the trick kit or just a plain rebuild kit?
                • Video_Master
                  • 10524
                  they are saying 650 dp, not 600. I wonder if they knew you did not have a 650.
                  • Turbo302
                    • 1528
                    Thats what I meant 600DP. The Dp's have better response IMHO. Get the trick kit, and get it on a dyno to dial in jetting.
                    Tim
                    1988 5.0 Notchback
                      thanks!
