underdrive pulley's
  • Scotts 94GT
    • 297
    underdrive pulley's
    I bought some MAC underdrive pulleys for my 5.0 and was wondering why the pulley off the crank was smooth. The one on my car right now has grooves in it that match the grooves of the belt. Is this normal? I don't want to throw my belt or something? I know that it is larger in diameter, so it will be turning less and I think that it will be closer to the water pump, but .... am i just worried about nothing?
    1966 Fairlane
    1998 Mustang
    2003 F250
    2009 CTS
  • -D
    eat shit..eat my shit
    • 2708
    my water pump pulley is completely smooth as well....I wouldnt worry about it if I were you...put em on...have someone start it, and watch the belt to see if it wanders, if it starts to wander have the person kill it. I wouldnt worry bout it much tho.
      Sounds like you are confusing the crank and the water pump pulley. Whe water pump pulley is the smooth one. Should be a piece of cake to do except the alternater which requires an impact gun. Best money I ever spent was on my pulleys. Have fun.
        Serious? You noticed that much of a difference?
          I didn't notice a big difference adding pulleys...
          • Scotts 94GT
            • 297
            What did you guys torque them down to? Mine didn't come with any info.
            1966 Fairlane
            1998 Mustang
            2003 F250
            2009 CTS
            • KrisR
              KNT-SHO
              • 12737
              TRDon is muy loco.
                I can explain, but I dont like typing. lets just say drive without them for a day after having them on and you will feel pretty naked.
                • Mustangmatt
                  The bobs...
                  • 10806
                  the alt and water pump just torque to spec. the crank ones just tighten as hard as you can because they probably supplied you with Hex bolts for that, actually I would tighten all of the pretty tight.
                  Crankshaft Pulley-to-Vibration Damper Blots 20-28 ft. lbs.
                  Water Pump Pulley-to-Hub 15-21 ft. lbs.
                  I found those on the net, but i would go tighter than that, dont forget loctite.
                  matt
                  • madmike
                    • Mar 2005
                    • 83
                    be careful,if you overtighten the bolts you will stretch them, thus weakening them. find the manual and torque to specs and use loctite.you can find this info at the public library
                    • MetallicPony
                      • 14093
                      i felt a big difference with my pulleys...and o/r h
                      • Zinc
                        yipyipyipyipyip
                        • 17324
                        If pulleys are added to mustangs, ESPECIALLY Cobras, they inherently become unbeatable. Its true...
                        Pure as the driven snow.
                        • Emart
                          Made
                          • 6019
                          sweet, then I'll only be mortal until saturday when im puttin mine on. what is "loctite"?
                          • worduphomefry
                            no fat chicks
                            • 11982
                            it's kinda like glue for a bolt. it will help it to not come loose
                            • Emart
                              Made
                              • 6019
                              gotcha
