Just finished my engine needs a dyno to run right just need a little help where to go and how much does it cost :3gears:
Where is the nearest Dyno
What did you run there, the stroker?Originally posted by DNeinstadtIf you're looking for a strictly engine dyno, I went to Wheeler in Blaine, they charge $60 per hour.. Jeff is a good guy.
DanDan Simons
'11 5.0, 400a, 3.73s, HIDs, ARH 1-7/8" longtubes, Forgestar CF5v 19x9/10, MPSS 275/295, GT500 axle-back, Steeda springs, AirRaid CAI, BBK 85mm, AED tune
ok dyno numbers before chip and tune 334 torque whp 285 after all done like seven pulls later I have 355 torque and 308 whp. Hitech did a great job casey Great tech. In another way I an dissapointed in my motors performance thinking to start all over again build a new motor this summer not sure were to go or sould I add boost hitech said try Nos 150 wet shot motor can handle it I have Je pistons and eagle rods any one have some ideas i would like to hit 400 whp+ nitro will give me 458whp but i dont really want to have to fill bottle every month not sure how nos works as far as usesage let me know
What else is in the combo. Heads intake cam exhaust. Seems low for a built 347. If your running stock heads I could see these number but a H/C/I stroker should put down around 350-380 RWHP. Is this a auto car.Progress. Should be fun.
sigpic
I would be interested to know the combo as well. My 347 is well beefed up, but with the C4/and convertor I believe the numbers can be skewed. Mine laid 328rwhp and 330rwtq. Main thing, I will post my 1/4 times when I get them2003 Redfire Cobra. Build Date 10/3/02. # 3562 of 8394.
try a bigger cam.Originally posted by 347Strokerok dyno numbers before chip and tune 334 torque whp 285 after all done like seven pulls later I have 355 torque and 308 whp. Hitech did a great job casey Great tech. In another way I an dissapointed in my motors performance thinking to start all over again build a new motor this summer not sure were to go or sould I add boost hitech said try Nos 150 wet shot motor can handle it I have Je pistons and eagle rods any one have some ideas i would like to hit 400 whp+ nitro will give me 458whp but i dont really want to have to fill bottle every month not sure how nos works as far as usesage let me know
I make horse powerz
the stroker list is 306 -347 dis je pistons eagle rods roush200 heads roller rockers edlbrock rpm2 intake 70 spacer and throttle cold air intake 24lbs injectors 2 5/8 long tube headers 3in all the way back cam is small or how casey put it little I agree i need a bigger cam
I havea comp cam in
duratoin at .050 intake 215 exhaust 220
lobe lift .3330 .3420
lobe separation 114.0
