2001 Infinity I30 ECU question
  • Sleepin96
    St. Croix Autoworks
    • May 2009
    • 1904
    So i need to have the ECU rebuilt for this 01 I30 I have sitting here. Anyone have a good local place that can do this for me.
    Best 11.14 w 1.61 60'
  • taank
    • 10278
    dealer orders a new one.
    Jake H.
      Why does it need a rebuild?
      • Sleepin96
        St. Croix Autoworks
        • May 2009
        • 1904
        The Idle air control valve went out and apparently when the iacv goes out it takes the ecu with it. The car would run and die instantly without you working the throttle, replaced the iacv and now it does the lopey idle, pulled the ecu, to check and it smells like my old fried sub amps from back in the day.
          Did you open it up yet?
          • Sleepin96
            St. Croix Autoworks
            • May 2009
            • 1904
            I have not.
            • octanehuffer
              • 5265
              Carquest has a pcm program
                Pop it open, De-solder and replace parts as needed.
                • Sleepin96
                  St. Croix Autoworks
                  • May 2009
                  • 1904
                  I opened it, burnt as hell. No way i can repair it myself. I'm gonna call car quest monday.
                  • Sleepin96
                    St. Croix Autoworks
                    • May 2009
                    • 1904
                      Sounds like it was designed without a proper buffer. Could call around some junkyards too, but ask about the return policy, some don't allow returns or ask an extra fee for the option.
                      • Sleepin96
                        St. Croix Autoworks
                        • May 2009
                        • 1904
                        I'm aware. I've checked all the local yards with no prevail.
                        • taank
                          • 10278
                          the idle air volume learn needs to be performed as well
                          Jake H.
                            To Infinity and beyond!
                            • ProRauder
                              Carpe Noctum!
                              • Jul 2007
                              • 850
