Anyone running AFR185's?
  • Mustangmatt
    The bobs...
    • 10806
    Just wondering if you are and if you had to notch your pistons and what kinda cam/combo you are running. Thanks!
    I had a set on a stock 89 shortblock with an F cam...
    I was one that didnt have to notch the pistons, barely any clearance though. I would certainly notch them at this point in my hobby.
    • MINNESOTA 5.0
      I FIX OTHER PEOPLES FUCK UPS
      • 2852
      89' NOTCH- 327 TURBO, C4
      • Mustangmatt
        The bobs...
        • 10806
        Im running an ecam. Read that 230 duration or less you can get away with it.
        • Mustangmatt
          The bobs...
          • 10806
          Originally posted by MINNESOTA 5.0 View Post
          I'm just trying to save us some work if possible
          • 94fobrah
            2012 RSN #3
            • 8820
            You need some rear disc's to slow down all that powa.
            90 LX 445CI N/A SBF
            Built By Dave Senderhauf JR
              i have them, did not notch my pistons.
              • MINNESOTA 5.0
                • 2852
                THE way matt drives and turns rpm's he needs to notch them.
                  Spark cut.
                    Originally posted by RNSF View Post
                    Spark cut.
                    That doesnt stop ptv issues.
                    • Mustangmatt
                      The bobs...
                      • 10806
                      Im working on that part too...
                      • Mustangmatt
                        The bobs...
                        • 10806
                        Could you be a little bit more specific? What cam you were running etc...
                        • Mustangmatt
                          The bobs...
                          • 10806
                          Screw it... Ill just make the valves notch it. Problem solved!
                            Pretty sure you will end up notching the pistons to get the 2.02 valves to have proper clearance...Stock pistons do not have much for valve reliefs...clay the pistons.
