Tiggin
  • 64fairlane
    • Jun 2026
    Tiggin
    Essentially valve cover won't get along with my master cylinder. I can butcher it up just need someone to tig a patch back in. Anybody?
    Hammer plus torch.
    • Guest's Avatar
      Hammer plus torch.
      Not sure that will do it without wrecking everything.
      • gutlas5
        "7718"
        • Dec 2005
        • 2656
        the master itself, or the booster
        10.89@123
        Originally posted by 87mustangguy306
        you can go to hell!! you can go to hell and you can die!!
          If youre scared your car will die a fiery death, I could do it for you?
          • Guest's Avatar
            Master no booster
            • Guest's Avatar
              Can do it off the car just never seen cast aluminum bend very well
                Maybe this is why no one makes swap parts for a 460 in an early 60's Falcon
                • Guest's Avatar
                  No one but me. Stock stamped steels fit fine but the tall aluminums look better
                  • Guest's Avatar
                    Wonder how much swap headers are worth?
                      I had some neat 460 marine valve covers, but they met their demise with the rest of the scrap pile.
                      • Guest's Avatar
                        Your end will come swiftly
                        • gutlas5
                          "7718"
                          • Dec 2005
                          • 2656
                          do diff brand alum vlave covers come in diff heights and widths?
                          10.89@123
                          • Guest's Avatar
                            Not sure these are Just too tall without modification but they look good ill just cut a chunk out for clearance and patch it back in
                              This could all be avoided with a SBC swap, would be much faster as well....
