Tiggin
  • 64fairlane
    • Oct 2026
    Tiggin
    Essentially valve cover won't get along with my master cylinder. I can butcher it up just need someone to tig a patch back in. Anybody?
    Hammer plus torch.
      Hammer plus torch.
      Not sure that will do it without wrecking everything.
      • gutlas5
        "7718"
        • Dec 2005
        • 2656
        the master itself, or the booster
        10.89@123
          If youre scared your car will die a fiery death, I could do it for you?
            Master no booster
              Can do it off the car just never seen cast aluminum bend very well
                Maybe this is why no one makes swap parts for a 460 in an early 60's Falcon
                  No one but me. Stock stamped steels fit fine but the tall aluminums look better
                    Wonder how much swap headers are worth?
                      I had some neat 460 marine valve covers, but they met their demise with the rest of the scrap pile.
                        Your end will come swiftly
                        • gutlas5
                          "7718"
                          • Dec 2005
                          • 2656
                          do diff brand alum vlave covers come in diff heights and widths?
                          10.89@123
                            Not sure these are Just too tall without modification but they look good ill just cut a chunk out for clearance and patch it back in
                              This could all be avoided with a SBC swap, would be much faster as well....
