351w/302 Interchange Questions
  • LongAndLow
    Drop and Destroy!!
    • 669
    I have a 351w that I am putting together... The block is 351w from a '85 f150, I am putting 302 gt40p heads on it, I know I need to have the mounting holes made bigger, and I assume run 302 headers. But how about for a cam, distributor, and intake? for the cam as far as I understand any non-roller 302 or 351w cam will work. if it's a 302 cam use 302 firing order. True? and if you can use a 302 cam will a 302 distributor work? Then for the intake I have no clue. any and all ideas will be appreciated! Thanks!
  • DNeinstadt
    Administrator
    • 12578
    For sure, the distributor is too short, the 351w is taller than a 302. Also, the intake is wider due to the taller deck block.
    You will probably want to find a set of headers that will fit the chassis of the vehicle (ie: specific 351w swap headers)
    What is the vehicle you are building this for?
    Dan
    • LongAndLow
      Drop and Destroy!!
      • 669
      Its going into an 86 f150 with a 3" body lift and a 4" suspension lift so I've got a bit of real estate to work with for headers I should not have many clearance issues if any. But you say I will for sure need a 351 intake and distributor?
      • Fast351
        I can't drive 55
        • Dec 2010
        • 119
        Yes, those are 351 specific. Cams swap.
          Yes...a 351 is taller deck thus need for different intake, go sit a 302 intake on your 351 with heads on and you'll instantly realize. As well as distributor.
            Mustang shorties will work for headers if you're looking to go cheap.
            • LongAndLow
              Drop and Destroy!!
              • 669
              Thanks fellas!
              • Old Man
                Elder Statesman
                • 5711
                The blocks are the same with the 351 having a 1.3" taller deck.
                The heads are fine, the exhaust will work but is restrictive even on a 302 so you may want to rethink them. You need a 351 dizzy, longer push rods and intake, cams are interchangeable using the right firing order. Are you going carb or FI?
                www.transport-graphics.com
                www.knowltonsthunderheads.com
                www.dukesraceshop.com
                www.meanstreetperformance.com
                www.fleetwoodcollision.com
                www.idealautoglass.net
                  What do you know.
                  • Old Man
                    Elder Statesman
                    • 5711
                    What do you know.
                    Since when is knowledge a prerequisite to contributing to the Shop Talk section?
                    Is there are new rule about knowing anything about what you post?
                      Touche'
                      I need a new block BTW
                      • Old Man
                        Elder Statesman
                        • 5711
                        Touche'
                        SVO 4 bolt or Sportsman?
                          I wouldnt do a sportsman . Go big or go home>
                          • Old Man
                            Elder Statesman
                            • 5711
                            PM me your plans
                            • LongAndLow
                              Drop and Destroy!!
                              • 669
                              I am going carb'd
