I have a 351w that I am putting together... The block is 351w from a '85 f150, I am putting 302 gt40p heads on it, I know I need to have the mounting holes made bigger, and I assume run 302 headers. But how about for a cam, distributor, and intake? for the cam as far as I understand any non-roller 302 or 351w cam will work. if it's a 302 cam use 302 firing order. True? and if you can use a 302 cam will a 302 distributor work? Then for the intake I have no clue. any and all ideas will be appreciated! Thanks!
351w/302 Interchange Questions
For sure, the distributor is too short, the 351w is taller than a 302. Also, the intake is wider due to the taller deck block.
You will probably want to find a set of headers that will fit the chassis of the vehicle (ie: specific 351w swap headers)
What is the vehicle you are building this for?
Dan^^^^^^^^^^^^^^^^^^^^
The blocks are the same with the 351 having a 1.3" taller deck.
The heads are fine, the exhaust will work but is restrictive even on a 302 so you may want to rethink them. You need a 351 dizzy, longer push rods and intake, cams are interchangeable using the right firing order. Are you going carb or FI?Don't ask, it's a midlife crises thing.
www.transport-graphics.com
www.knowltonsthunderheads.com
www.dukesraceshop.com
www.meanstreetperformance.com
www.fleetwoodcollision.com
www.idealautoglass.net
Originally posted by Old Man View PostThe blocks are the same with the 351 having a 1.3" taller deck.
What do you know.
Since when is knowledge a prerequisite to contributing to the Shop Talk section?Originally posted by LES View Post
What do you know.
Is there are new rule about knowing anything about what you post?
Touche'Originally posted by Old Man View PostSince when is knowledge a prerequisite to contributing to the Shop Talk section?
I need a new block BTW
SVO 4 bolt or Sportsman?Originally posted by LES View PostTouche'
PM me your plansOriginally posted by LES View PostI wouldnt do a sportsman . Go big or go home>
