351 - pinging under load
This topic is closed.
    Originally posted by TRDon View Post
    Well I guess CR isnt an issue.
    Pretty sure i already covered that part.
    the timing is off and the rockers are fucked up.
    fix both of these things and all will be well in the jew world again.
      #77
      CR was a speculation until 2 posts ago so you were guessing. Timing is not off, you missed that part. You havent been folllowing along very well have you?
      • thebigT
        That was your sister?
        • May 2010
        • 511
        #78
        what is the part# in the pistons? and it is 40 over? dish pistons are hard to come by for a 351w.
        If we were to build a freeway into outer space, it would be possible to prove the theory of time travel using an 03 Cobra.If it dont have 3 pedals it aint no HOT ROD !
        http://www.youtube.com/watch?v=LDNsz9PCq1c
          #79
          40 over, dished.
          Should have taken pics
          had .040 stamped in em
          I bought the Motor, trans and transfer case for $300... Sold off transfer case and trans for $300...
          • thebigT
            • May 2010
            • 511
            #80
            A stock 351w piston is close to -11.7 but most aftermarket are -3 to -6 flat tops and if it is 40 over the cr might be higher than you think. I don’t know why someone would put dish pistons in it, well forced induction or NOS but it was a cheap motor so…. Need more info.
              #81
              nitrous loves high compression motors. Forced induction doesnt.
                says who?
                • thebigT
                  • May 2010
                  • 511
                  #83
                  I thought big NOS engines were lower compression like 8.5-9 to 1? Are you talking 500 or 50?
                  "If you take an engine that has 10:1 compression it will handle say 150 hp of nitrous, before detonation becomes a problem.
                  If you raise the compression to say 12:1 it may only handle 50 hp before detonation, whereas if you lower the compression to say 8:1 it may handle 500 hp."
                  this is what i found in 30 sec.
                    #84
                    solid reference, will read again./
                      just seen the pics, please stop while your ahead. id find some one to come setup the valve train for ya
                        Shitty, it wasnt pinging.
                          Holy mother of francis, that is fucked!
                            And you put heads on this motor and didn't notice that?? Were you doing this in Canada in the woods at midnight with no light and no moon while being sprayed in the face with bear mace?
                            • Old Man
                              Elder Statesman
                              • 5711
                              #89
                              Guessing nobody checked the valve train geometry.....
                              At least I fucking hope not.
                              www.transport-graphics.com
                              www.knowltonsthunderheads.com
                              www.dukesraceshop.com
                              www.meanstreetperformance.com
                              www.fleetwoodcollision.com
                              www.idealautoglass.net
                              • ds5dot
                                RS/N Champ 2009
                                • 1657
                                #90
                                This is a joke right???
                                Thanks to:
                                http://transport-graphics.com/
                                http://knowltonsthunderheads.com/
                                http://www.normstire.com/
