SNOWMOBILING
  • waterbug1999
    Got Beer?
    • 3554
    Clutching is more important than dropping a jet size or throwing in some reeds. You'll gain nothing if it can't put it to the ground.
    I'm still running the same jets Arctic cat put in the day they made it. I never changed a thing on my motor. It's all clutching on mine. The whole tweaking every little last bit and running it on the edge thing baffles me. People will spend $$$ on jetting, reeds, pipes, blah blah blah and now EGT gauges, and think they're going to break record speeds, when actually they may only gain 2mph WTH Just run the damn thing and enjoy it. I'd rather pull the rope and ride than try and figure out what jets I'll need in the morning and than swap them in the afternoon because it's warmer out, and then switch back at night because now it cooled off again. DUMB. If you want to go faster, buy a bigger sled for christ sakes.
    I think you are missing the reason why I added the reeds... The stock boots were torn so I had too.. Now its just dialing it in...
    If I could spend the same amount of money to upgrade/replace what was broke and make a few ponys then you would be a fool not to. I dont like working on the damn thing, but once I get the jets/carbs figured out now she will run like a champ. The EGT thing would be a time saver in the long run if you could simple go out and read whats going on in the motor, plus it could save your motor from melt down if something did happen.
    1999 Trans Am
    10.71@126.9 / stock shortblock
    • 1moretoy
      EAT SLEEP FISH
      • 27018
      I know your boots were torn. BUT, you won't gain what you "think" you will with your fancy reeds. I've heard people say they actually went slower after they put in aftermarket reeds and jetting because they changed nothing else to work with the new reeds
      • waterbug1999
        Got Beer?
        • 3554
        You won't gain what you think you will with your fancy reeds.
        But you will gain crisper throttle response.. Like I said, I had torn boots, so I fixed the problem.
        1999 Trans Am
        • 1moretoy
          EAT SLEEP FISH
          • 27018
          You know this how? Is it because it's what the manufacturer said. Crisper throttle responds can come in to play with just changing the needle position or needle size.
          I'm not trying to piss you off. just relax a bit before you start throwing more money at it.
          • waterbug1999
            Got Beer?
            • 3554
            Just reading what others have posted on sled sites..
            1999 Trans Am
            • waterbug1999
              Got Beer?
              • 3554
              I just added the EGT
              1999 Trans Am
              • 1moretoy
                EAT SLEEP FISH
                • 27018
                There is A LOT of good advice out there. But there are a lot of people that are more than happy to spend your money
                • waterbug1999
                  Got Beer?
                  • 3554
                  yea, it was just other people like me that added whatever and chose to post up results.. the boyesens had a hard casing so I wont have to worry about cracked boots anymore which could cause a melt down..
                  1999 Trans Am
                  • 1moretoy
                    EAT SLEEP FISH
                    • 27018
                    OK. Well good luck then. Maybe if you get that thing figured we can do a little local ride with some of the other knuckle head sledders
                    • waterbug1999
                      Got Beer?
                      • 3554
                      working on it this friday and hitting the trails south of town this saturday, thats where the snow is at.
                      1999 Trans Am
                        • 1moretoy
                          EAT SLEEP FISH
                          • 27018
                          did I studder?
                          • 1moretoy
                            EAT SLEEP FISH
                            • 27018
                            "BABY STEPS"
                            • waterbug1999
                              Got Beer?
                              • 3554
                              "BABY STEPS"
                              im throwing the 400 jets in
                              1999 Trans Am
                              • 1moretoy
                                EAT SLEEP FISH
                                • 27018
                                Good, Then that will end all this nonsence.
