Service Entrance cable, from Main Panel to 125 Amp sub-panel 4-wire 100' run inside, what gauge copper??
Sub-panel
Tags: None
3 phase I take it?Originally posted by HackWhy spend all that money just to get a worn out copy of a small block Ford? It's going to be in the junk yard for a reason. I understand you have a religion called LS motors and you have faith that the LS motors break the laws of physics and work better and cost less than anything else ever built. Plus they never wear out.
I disagree.
Go #1awgOriginally posted by HackWhy spend all that money just to get a worn out copy of a small block Ford? It's going to be in the junk yard for a reason. I understand you have a religion called LS motors and you have faith that the LS motors break the laws of physics and work better and cost less than anything else ever built. Plus they never wear out.
I disagree.
You can technically go #2 but at that lengh, and the cost difference, I would go #1 unless you are looking at a pretty light loading schedule fo rthat panel.Originally posted by HackWhy spend all that money just to get a worn out copy of a small block Ford? It's going to be in the junk yard for a reason. I understand you have a religion called LS motors and you have faith that the LS motors break the laws of physics and work better and cost less than anything else ever built. Plus they never wear out.
I disagree.
Bill, let me know if you need cable. I can check with our vendors.LOOK HERE:Originally posted by Pony5.0but hey we have broken up 2 times in the past week and she keeps crawling back to me and she told me she would never crawl back to a guy and i am the only one. she tells me she loves me and everything!
Originally posted by NickYou ever make 150k per year? LOL, j/k we all know you're way too dumb to achieve this.
Originally posted by MisterCMK View PostBill, let me know if you need cable. I can check with our vendors.
I cannot find any 1-1-1-3 in Fargo I guess I'll go with 2/0-2/0-2/0-1/0 AL.
You think 100' will roll up and fit in a suit-case.. I don't....
Originally posted by XJHEAD View PostI cannot find any 1-1-1-3 in Fargo I guess I'll go with 2/0-2/0-2/0-1/0 AL.
You think 100' will roll up and fit in a suit-case.. I don't....Originally posted by HackWhy spend all that money just to get a worn out copy of a small block Ford? It's going to be in the junk yard for a reason. I understand you have a religion called LS motors and you have faith that the LS motors break the laws of physics and work better and cost less than anything else ever built. Plus they never wear out.
I disagree.
Originally posted by TRDon View PostMake sure that the breakers you are terminating in is allowed the terminations of al wire. It should be but just double check before proceeding.
I have a way to fit them if they don't
Thanx for the heads up about the size issue too....
