Any1 available to give me some help? I'm in Bloomington.
    As usual i seem to be doing more harm than good when turning wrenches. If any1 can come over just long enough to help me track down a vacuum leak it would be awesome. I can hear it but can't keep the car running long enough to start it, get out and search. It kills before i can open the damn door.
    Call me if you can help. 612-384-0966
    Thanks.
  • ACRucrazy
    • 27924
    Turn up the idle screw
      No idle screw. Electronically controlled.
      • 1moretoy
        EAT SLEEP FISH
        • 27018
        Sounds like a big leak. Check the break booster hose.
          It whisltes really fucking loud. I just replaced the 2 base gaskets on the carb. There is 2, 1 really thin 1 under the spacer and 1 thick on top of the spacer. I've checked every piece vacuum hose i can see. It better not be the fucking gaskets.
            Put a brick on the accelerator pedal, then turn the key,
            Randy
            • Max Power
              • 13086
              If you are commited to Fords, you must buy a remote starter switch.
              • ACRucrazy
                • 27924
                Screw driver on the solenoid on the firewall
                  That still leaves me with just 1 hand to work with while the other keeps the car running. Sometimes you just need 2 people, like now.
                  • ACRucrazy
                    • 27924
                    Once the car starts by arcin the solenoid use the throttle shaft on the carb to keep it running?
                      Drive it over here and I'll help
                        94YellowSleeper to the rescue. 1 of the base gaskets was not seated well enough. Thanks for the extra set of hands Ryan.
                        • 5O4U2NV
                          The eternal optimist
                          • 2079
                          glad i could help
                          -Member of WCR Inc.
                            damn rookie
                            • The Russinator
                              • 5648
                              Ryan
