1979 Corvette
  • 5.0stang85
    Hater's be hatin'
    • 7065
    1979 Corvette
    I have a 79 Chevrolet Corvette L82 project -Got it from a guy that pieced it together from a rolling chassis, put a motor/trans in it and got it running, I have since put a few nights into it making it a little better, and now it's someone elses turn- I have 3 other cars that require my attention so this is a chance to get a nice start to a project car that is 90% complete plus it runs and drives! open to trading for other cars/trucks as well...
    The goodish
    Clear MN title/plates/tabs (good til August 2013)
    It runs and drives
    Has a fresh rebuilt 350(mild cam, Edelbrock intake/carb) motor runs great and has a nice lope to it (shakes whole car)
    Rebuilt stock TH350 trans
    At least 4.10 gears in the rear end (cruising @50mph is around 4,000rpm)
    Good BFG T/A rubber (235/60/15's @ 50%+ tread)
    Newer OEM cat and stock mufflers
    New front shocks
    I got it running better by re-timing the motor (was a good 30* off), and setting the idle mixture as good as I could get it. (with a vacuum gauge)
    All gauges work but the clock
    New air filter, new fuel filter w/ pressure gauge, new fuel pump, new Taylor plug wires, fresh oil change, and new throttle/TV cable brackets
    Both side windows work with the switches
    Includes a box full of parts including the glove box, front air dam, both door panels/arm rests, console sides, 4 new head lights, the head light bucket covers, random screws
    The badish-
    Brake pedal is spongy (might need a master cylinder but they work as is)
    Interior needs a full restore (comes with a new carpet kit/ steering wheel cover, and couple other little things) it's in rough shape as is though
    Head lights don't work (won't turn on- can't figure out why- all other lights work though)- they do go up and down but one of the vacuum solenoids leak so they're not hooked to vacuum but the buckets are free for the lights to go up and down and the vacuum system does function minus the leaks in the system
    A/C is not complete(1 line was cut and missing pump/brackets)
    Needs an alignment
    The passenger door handle needs adjusted as it won't open with out messing with the latch
    Needs a patch in the drivers side floor (steel)
    1 crack found in the main body (driver rear 1/4 behind wheel) front and rear bumpers have cracks but present ok
    Looks like the car was Red at one point and resprayed poorly Black (can see Red under the Black in the vents behind the front wheels)
    needs U joints/unit bearings soon
    Needs a interior screw kit and seat bolts as there are no screws/bolts
    The rad core support is rotted out in the lower portions but new one's are available and everything is still being held up ok currently
    We have sent the title into the state and do not have it back yet but yes there is a clear MN title- Therefore we will be selling the car with a contract stating the title once received (if not by the end of the auction/ time of pick up) it will be signed and sent certified signature required mail to the new owner.. (both parties will sign and date and get a copy or said contract to be legal) please bid with confidence!
    The car honestly needs a full frame off resto the pics make it look nicer than it is - or drive it after putting a little into it as a beater. Doesn't shake at speed, and has a solid frame- just trying to get what I bought it for..
    Bring a trailer as it is not drive-able for more than a few miles.. (due to needing U joints/ and the cruising RPM of the motor)
    sorry for the novel just want you to know what you're looking at before you make the 2.5+ hour trek to look at it..
    Cooter's Coatings
    Hudson WI
  • Silversixspeed
    • 1471
    Pro selling tip #42 - Never use pictures of a car on a dolly/trailer when trying to sell said car.
    • 5.0stang85
      Hater's be hatin'
      • 7065
      the pics are from the day bringing it home it does run and drive.. as seen by the exhaust in the pic
      we just didn't want to drive it 250 miles home..
      Cooter's Coatings
      Hudson WI
      • sonicx
        TCS Team Member
        • Jul 2011
        • 689
        Hmmm.... Any rust?
        • 5.0stang85
          Hater's be hatin'
          • 7065
          Originally posted by sonicx View Post
          Hmmm.... Any rust?
          none seen in the frame, driver floor has a crude patch, and front core support has rot
          Cooter's Coatings
          Hudson WI
          • Silversixspeed
            • 1471
            Where is it located at?
            • 5.0stang85
              Hater's be hatin'
              • 7065
              Clitherall MN sorry I haven't updated my profile cause well I'm never on here
              Cooter's Coatings
              Hudson WI
              • 5.0stang85
                Hater's be hatin'
                • 7065
                TTT
                Cooter's Coatings
                Hudson WI
                • 5.0stang85
                  Hater's be hatin'
                  • 7065
                  Bump got a few more parts for it (head light covers, new console sides, more carpet, ect...) got it running better after resetting the timing and messing with the Ede carb a bit.. it also has no frame rot in the rear wheel area..
                  need it gone trying to break even at $3,000.. runs and drives- new rebuilt 350(newer 4 bolt heads/Ede intake/carb/air cleaner/ mild cam)/ rebuilt TH350, at least 4.10 gears in it (50mph @ 4,000rpm in 3rd) so it must be towed... oh ya clear title!
                  Cooter's Coatings
                  Hudson WI
                    Am I on drugs, or does it have Vortec heads on it????
                    • 5.0stang85
                      Hater's be hatin'
                      • 7065
                      I was told "truck heads" by the pervious owner LOL they're 4 bolt valve covers
                      Cooter's Coatings
                      Hudson WI
                      • taank
                        • 10278
                        Lots of heads have those valve covers.
                        Jake H.
                          He was a perv, eh?
                          • 5.0stang85
                            Hater's be hatin'
                            • 7065
                            Sorry previous* I tend to type fast and not check spelling
                            Cooter's Coatings
                            Hudson WI
                            • BirdofPrey97
                              • 1550
                              If a casting number is available off the heads let me know. If a part number is available or better description of the intake let me know as well please.
                              Honor, Grace, and Diginity
