crazyspeed.com "ET Second Club" Photos/Updates Inside
  • 1BADRZ28
    X235
    • 5189
    #16
    Hmm, I raised a buddy's at MCSO last fall and guess what? His ET changed. It was an Outlaw car too. These tires have changed considerably since the 1990's-2000's. Low air pressure isn't needed, unless your tires are from those years. My guess is the suspension is off if you lose 60ft on the increase.
      We run 10-12 in Billy's depending on the day. 28 X 14.5 X 15 ET STREET NON DR.
      Scott I think what they are talking about is how you are wrinkling the actual tread or contact patch of the tire. That isnt good.
      • iceman496
        • Aug 2006
        • 1422
        #18
        Ok I understand that. But I have a 17.5 x 32 which is a big tire most of you have a smaller tire that does not require low tire pressure. But on my car the way it is set up I get low 1.4 60 foots with the tire pressure at no more than 61/2 pounds. But for some reason when I bump it up to 7-8 pounds it gets mid 1.4's. I am not saying I won't try tire pressure this year and do some suspension adjustments it might make a difference.
        IF IT AINT BROKE I'LL BREAK IT!! (MONTBOO)
        ET 8.74 @ 157.85 THRU STREET TRIM ON E85 small super charger on spray
        www.crazyspeed.com
        www.racecarrevolution.com
        • 94fobrah
          2012 RSN #3
          • 8820
          #19
          Kevin Pallow
          1990 Mustang
          438ci SBF N/A (pump gas)
          6.45 @ 108 in the 1/8
          275 radials
          Wouldn't be where I am today if it want for all the help from.
          Transport Graphics, Inc. is Springfield's premier source for vehicle graphic design and installation. We also can produce signs and banners. BIG IMAGE. BIG IMPACT.
          And Gramps
          90 LX 445CI N/A SBF
          Built By Dave Senderhauf JR
          • iceman496
            • Aug 2006
            • 1422
            #20
            I have heard that you want to put down as much of a foot print on a big tire to get the best traction. Plus there is an extra 285 lbs on the driver side so the tire might wrinkle more. Lol
            www.crazyspeed.com
            • shagwag
              In Memory of Bill J. Gefre
              • 4234
              #21
              Dan Gefre
              1983 Malibu wagon
              476 pump gas motor built by mike Sterling and rr performance
              63 no2 jet
              5.90 @ 116 1/8
              9.300 @144
              Huge thanks to TNT
              5.38@130
              8.40@161
              Originally posted by sinSStr
              Originally posted by crazy
              i am the one that cant spell
              www.tntraceshop.com
              • 5-door
                www.jtracecraft.com
                • 5001
                #22
                You have other issues going on then. Your tire pressure shouldn't need to be quite that low. Big tires do take less pressure, but they shouldn't need to be that low. You're just beating up the side walls and shortening the life of the tires. It's also costing you e.t. I believe your bigger problem has to do with shock settings, spring rates, or maybe 4-link adjustments. You should still be doing better 60 foots than 1.4X.
                • mcshocks
                  • Sep 2010
                  • 61
                  #23
                  He's Probbably runing to big of a tire, his Tire height is changing with more air in the tire changing gearing slightly which is effecting his 60ft's. Try a slightly shorter tire with more air pressure & I bet his 60ft & ET improves.
                  1/4 mile: 11.74 @ 115.91 mph on a 1.606 60'
                  • Brownman
                    The underpowered one.
                    • Mar 2006
                    • 5853
                    #24
                    Originally posted by 94fobrah View Post
                    Kevin Pallow
                    1990 Mustang
                    275 radials
                    And Gramps
                    Fuck if I'm running you again, I only trap 10mph more in the 1/4
                    Aaron.
                    • crazyspeed.com
                      Sprayin' Korn
                      • Feb 2012
                      • 495
                      #25
                      Brian Carpenter
                      Skinny Kid Race Cars 04 Mustang
                      Full Tube Chassis Carbon Fiber Bodied Car
                      Alan Johnson 481X (526ci)
                      Twin Precision Pro Mod 94s
                      Est 3000+ hp on Alky
                      Best 1/8 mile of 4.20 @ 196
                      Completely Updated for 2012, updates coming soon on crazyspeed.com
                      SUPPORT YOUR LOCAL RACE TEAM
                      • lark-o
                        • 10489
                        #26
                        • 1moretoy
                          EAT SLEEP FISH
                          • 27018
                          #27
                          Hey Scott, maybe the 10th you give up in the 60ft may turn into a 2/10th gain at the other end with more air. With the air pressure that low, it would seem to me that you have to "push" the tire more than you're riding on it. Not sure if that makes any since but i think of it as trying to ride a bike with a low/flat back tire.
                            Do you have the training wheels off yet?
                            • 1moretoy
                              EAT SLEEP FISH
                              • 27018
                              #29
                              No, Thats why I claim to be no expert at anything
                              • iceman496
                                • Aug 2006
                                • 1422
                                #30
                                Dam I knew I was for getting something! Take the training wheels off. Lol
                                www.crazyspeed.com
