I understand how your getting it to work, but there are stresses that may catch up to you and show up in extreme wear.
Loosten the nut in the linkage joint to the factory shifter a couple of turns and see what happens when you move side to side. It should twist in two directions, the same angle as your new shift arm vertically and horizontally. I'm just saying that the joint on the factory shifter is critical. You could help this by making the link end with a larger vertical surface area by making that end a "T" shape. That wouldn't remove any horizontal swing angle however.
