stock 91 fox body 5.0
  • 91stang
    • Jul 2010
    • 32
    I just bought this 91 foxbody mustang and it is bone stock pretty much i know they have about 200 hp stock i really want to add hp but dont know where to start i want to add alot but also dont got a bunch of money this is my 1st real muscle car
  • 91stang
    • Jul 2010
    • 32
    also whatever i do how much hp gain will it give me?
      Exhast and intake is a good start.
        AOD or 5 speed car?
        • 91stang
          • Jul 2010
          • 32
          AOD
          • Odrapnew
            Everyone likes being blown.
            • 2880
            Cheapest mods(i.e. free) you can do that will net about 10hp is: bump the timing up and remove the stock intake air box silencer(inside the fender). The timing will also give much better throttle response.....assuming it's currently at the stock 10 degrees.
            Also, a full tune up(plugs, wires, cap and rotor) may help depending on how old the current stuff is.
              Stock aods don't like added power, know that you will be changing within a year of modifying the car.
              Built aods on the other hand can handle quite a bit of power. Something to think about.
                As mentioned before, simple things like adjusting the ignition timing, pulling the air silencer, full exhaust (headers to cat back), under drive pullies, electric fan. There is a lot of stuff you can do for cheap.
                The factory AOD is pretty weak in these cars so be aware of that.
                Plan out your mods, that way you are not spending money twice on certain things...
                  Just get a cold air intake and some underdrive pulleys. They are both cheap and will give you very noticable results. Keep it simple for now.
                  Do this and you won't be disapointed, or broke.
                  • loads
                    Slow red ford mafia member
                    • 1962
                    The most noticable thing I did was gears and a carbon-fiber limited slip.
                    Probably the best bang for the buck...
                    :geeza: -Member of WCR Inc.
                    Originally posted by Nifty
                    Can you please refrain from using logic? You're going to start making liberals cry.
                    • Turbo302
                      • 1528
                      After doing the common 10-min tune-up stuff (timing, silencer, tps), get some headers, off road h-pipe, and a cat back exhaust system.
                      To save the AOD, get a good brand shift kit, and a slightly higher stall torque converter (26-2800 rpm stall). This will make the AOD much more fun and able to lite the tires from a dead stop.
                      I had a winter beater 88 GT that I did the above to and it made it a whole different car even with the 2.73 gears. For a purely street car, I would go 3.27-3.55 gears with the 2800 stall. If you keep the stock torque converter, 3.73's will get it reving a bit quicker, but still wont have the "punch" a higher stall torque converter gives.
                      1988 5.0 Notchback
