Help: Ignition Mount Location
  • Meegs
    AA for Mustangs
    • 3062
    I have been trying to relocate my ignition location and I’m at a loss. So I was wondering if this looks like a suitable location or not. I am also wondering if passing Tech at the strip; would this would work? I can not find a well suited place under the hood. I was thinking about making a mounting bracket near the factory air box would be a good idea. But, then if the blower blew a belt I am afraid it would slap the snot out of my ignition box. The only other place I could find would be under the cowl. I was hoping to someday mount the nitrous solenoids there so it would make that spot quite clustered.
    The fitment & room is fine for my driving style, so the main question is. Should I mount it here, or search for a better location? Also has anybody heard of these arcing or blowing up? Can I pass Tech?
    Your thoughts?
    93 Teal Cobra #2531
    Turbo Cobra MAFIA
    1 of 452
  • Odrapnew
    Everyone likes being blown.
    • 2880
    I've seen people put it on the passenger side like that before but more on transmission tunnel. As for passing tech, I have no idea.
    • fastkeen
      HONK HONK
      • 296
      My 6A was mounted under the drivers seat. Don't know why It wouldn't pass tech. How hot does a 7a get. I would be worried that I would always be hitting it where you have it now.
      90 5.0 GT 4R70W New setup in the works.
      11.84 @ 113 1.64 60' Dynoed 428hp 419tq Dyno Vid Dyno sheet See it run
      • Meegs
        AA for Mustangs
        • 3062
        Yeah, I dunno. I just can't find a good place for it. Wish it were smaller so it would fit under the seat. I guess I'll just drill some new holes in the firewall and mount it on the passenger side. I just never have good luck with passengers feet kicking into things! Like I'll never do kick panel speakers again, LoL!
        93 Teal Cobra #2531
        Turbo Cobra MAFIA
        1 of 452
        • jp67stang
          bet ya cant do it like me
          • 1820
          looks like it will work and y not just build a cover to protect it
          mustangs are for fags
          • flstci71
            More Ovaltine Please!
            • Jan 2007
            • 753
            I was thinking about the same thing, but on the passenger side. Couldn't you mount it over there with some sort of a cover?
            • taank
              • 10278
              looks terrible
              Jake H.
                I wouldnt put somthing that uses cooling fins and gets hot under my shorts-laden legs. That and the discharge noise sucks and will get really old right there.
                  I never mount MSD boxes in the engine bay.
                    I always mount the ignition box under the passenger seat.
                    Although the box you have is quite hefty. Why not mount it in one of the fender approns?
                    • Meegs
                      AA for Mustangs
                      • 3062
                      With the Anderson Power Pipe I have room on the fender apron, but because I am using such a poorly designed blower belt setup I throw them quite frequently. Before the Anderson PP I just quickly fabbed up a K&N air filter and blew a belt once. The belt took out everything on the apron. So that is why I am gun shy on mounting it there. I also use to mount the 6a’s under the seat, however this 7a will not fit
                      But the job’s done already. I mounted it in front of the passenger seat. Just took out the Uni-bit and started drilling holes.
                      93 Teal Cobra #2531
                      Turbo Cobra MAFIA
                      1 of 452
