93 Escort 1.8L Broken Speedo Gear Fell into Transmission
    My axle seal was leaking. I pulled the axle and replaced the seal. I then went to refill the trans via the speedo sensor/gear (that's how you do it on these 1.8l mazda engines). When I pulled the sensor/gear assembly (looks like a standard ford VSS) out the gear didn't come with because it broke below the clip. It fell into the case and I can't see it at all.
    I figure I have 2 options. Replace the gear and let the other plastic one get crushed and hope the trans survives. Or remove the trans and split the case.
    Recommendations?
  • xjfish
    siiiiiiick!
    • 7357
    No way you can probe around in the case with something? The correct thing to reccomend is probably that it needs to come out of there but nobody wants to do that. (including myself) OrangeCrush it up, change fluid, change fluid again. If it drops to the bottom, chances are it will be fine there. If any chunks were to find their way through the pump, bad stuff is going to happen.
    I dropped a plastic gear lube bottle cap in my front diff and could not get it out. It has been great for 3 years since. "Friction Modifier"
    1987 Oldsmobile Cutlass Ciera
    • gutlas5
      "7718"
      • Dec 2005
      • 2656
      it's a 5 speed right?
      10.89@123
      • HerrKooled
        • 12060
        This is true, whenever i dick around inside of a diff i drop some bullets in the bottom. It keeps you on your toes.
        • Jeffescortlx
          Frum roll
          • 2003
          Did the metal clip fall off too? Or did the gear break around the clip?
            The gear broke below the clip, so I have the metal clip and a little green ring. They gear half is in the case.
            It's a 5 speed so there is no pump.
            I have time to get back to it now. I'm going to try to drain all the fluid to see if I can see it. Otherwise I think I might pull the trans and see if I can tip it upside down to get the gear to fall back out.
              I drained the fluid. I can't see the gear any where. Fuck I don't want to take this bitch out as I just had it out to do the clutch. Maybe it's time for a new car.
              • Beavnasty
                • Mar 2010
                • 1336
                Let her buck. Doubt a plastic gear is going to ruin moving metal
                parts. Just my .02
                Originally posted by NOTNSS
                I masturbate while watching the new Oprah network, TOTALLY WORTH IT!!!!!
                07' 300 SRT8 - Tuned by some Kyle guy 382whp 392wtq
                • TitaniumGT
                  • 11042
                  I'd let it bust it up too. Its just plastic.
                  446RWHP and 585RWT
                  Vortech S-trim
                  346rwhp and 314rwtrq
                    Drive it for 10k, it will come out when you drain the fluid.
                    • gutlas5
                      "7718"
                      • Dec 2005
                      • 2656
                      i've been lookin for a hornet car...how much? lol
                      10.89@123
                      • xjfish
                        siiiiiiick!
                        • 7357
                        How much are you looking to spend? I may have just the unit for you.
                        • gutlas5
                          "7718"
                          • Dec 2005
                          • 2656
                          What u got?
                          10.89@123
