Tq converter shudder fixes
  • LilRoush
    TRDon's little spoon
    • 2214
    Got a nasty vibration in my Exploder Sport. Everything I can find points to the tq converter (sounds like a very common issue in these things). Anyone have a real world fix without putting a new one in?
    I tried the Lucas trans additive that the guy at the store suggested, but it didn't do crap.
    Wanna get this fixed so I can get my blower set up back on and tuned.
    ~Matt
    1998 Roush M112: Aluminum block 4.6 2V T56 1 of 1 made
    1999 SVT: Daily driver, part time track car
    1970 Mach 1: Resto-modded 351W
    2000 Roush #5004: World's FIRST M112 supercharged V6 Mustang 1 fo 106 made SOLD, but not forgotten.
  • iamtheshaner
    • 3566
    Try changing the fluid and filter especially after adding the magic mechanic in a can
      buy a new converter now or buy a transmission and converter later.
      its your choice.
      • LilRoush
        • 2214
        Suggesstions for a new one that will take a beating more than the stock one?
        This whole auto trans thing is new to me.
        ~Matt
        • I Tried
          Pull my Winch Line 4 Me.
          • 6103
          Flush trans with Mercon 5 fluid and add 1 bottle of lube guard from napa and it is your best chance of fixing torque converter shudder other than replacing it.
          • LilRoush
            • 2214
            Can some explain what the shudder is exactly??
            ~Matt
            • iamtheshaner
              • 3566
              It's the lockup slipping similar to clutch chatter from a worn disk/warped fly/pressure plate in a 3 pedal.
                Torque converter clutch is on its way out. And when it shits out it'll wipe the tranny out also.
                • mark_eych
                  • 1442
                  Is this for a 4R70 then? I have one with 45k on it. Come buy it with your gears.
                  • Chrm97PI
                    268ponies with more onthe way
                    • 3413
                    lentech ftw!
                    • octanehuffer
                      • 5265
                      If it is a 4R70W behind a 4.6, you MUST center the converter to the adapter plate with a special tool. FYI. It is not just a simple converter swap(unless you have the tool).
                      • Chrm97PI
                        • 3413
                        i have not heard of this before
                        • xjfish
                          siiiiiiick!
                          • 7357
                          nor have I...details?
                          1987 Oldsmobile Cutlass Ciera
                          • Turbo302
                            • 1528
                            Both the red bottle Lube Guard and the squeeze tubes of shudder fix really work wonders.
                            I have used them on multiple occasions with awesome results.
                            Only use the Lube Guard products. All the others dont cut it.
                            Tim
                            1988 5.0 Notchback
                            • xjfish
                              siiiiiiick!
                              • 7357
                              I've never used anything "Lubeguard" except their trans cooler flush. Good stuff eh? I'm really considering picking up a car with a GM 4T65E-HD with higher miles and I'd like to do whatever I can to make the trans last.
