Transmission stuck in reverse
  • jjgeib
    blakstang
    • Aug 2008
    • 28
    I have a manual tranny in my 00 GT. Recently its been sticking in reverse. On most instances i can get it to come out, but last night I backed it into the garage and it will not come out of reverse. In the past I have been able to roll the car back and it would pop out. When i push the clutch in i can get it to come out of reverse but not completely. It feels like its stuck between reverse and nuetral (dont think thats possible). I can shift smoothly through the rest of the gears. I have a MGW short throw on it. I took the shifter a part last night and it looks fine. It started acting up a last year. I changed the tranny fluid to Royal Purple syncromax and it seemed to help for the past few weeks. I tried reseting the clutch (holding it up), I removed my floor mat and the clutch seems to be all the way in. Any help would be appreciated. Thanks
    Mine did that a long time ago. Id back up "aggressive" and it would get stuck where id have to punch it forward. Does this happen just gently backing up?
      this is why you cant have nice things.
        I has nice things
          I has nice things
          you punch them, are aggressive and they are always broken.
            Thats why i broke so many trannys last year.
            • jjgeib
              blakstang
              • Aug 2008
              • 28
              I dont back up too aggresively... im usually just coasting because the only time i really use reverse is when i back into the garage. Trying not to back into the lawn mower. I does come out easier if i start the car and go in reverse about 5 feet and slip it out of reverse. However, It seems to be sticking more now. I have to give it a quick hit upward to get it to pop out and this afternoon that didnt work. Its now sitting i the garage in reverse.
                Do you have a garage door in the rear of your garage?
                • jjgeib
                  blakstang
                  • Aug 2008
                  • 28
                  No. I have to push the clutch in and push the car forward at the same time!
                  fun times
                    fun times
                    I chuckled a little, sucks though.
                    • YouNeverSawMeHere
                      TCS' Commodities Specialist
                      • 9057
                      Check the level and condition of your transmission lube.
                      It maybe low and or losing its lubrication properties
                      Available on Amazon
                      >>Click here<<
                      • octanehuffer
                        • 5265
                        Ummm. Poor advise
                        • Killer Capri
                          Bumpin it up to 10L
                          • 4968
                          take sledge hammer, make adjustments. profit.
                          after youve lived though mine, hell is just a summer home.
                          • octanehuffer
                            • 5265
                            Will have a faceplated TKO 500 available shortly. All your problems will go away with sticking in reverse. Buy my product.
