trailer loading question
    allright i have everything loaded in the trailer (4 wheeler, toolbox, excuse generator, fuel, oil, fridge,ect) but the car as of now. im guessing there is 1500lb in the front of it right now. would i be safe loading the car backwards to get alittle weight off the front, or should i just load it forwards like normal. car weighs about 3400lb's so im guessing backwards it will still have more weight towards the front of the trailer.
    anyone else do this without issues. im new to enclosed trailers and dont want to be reloading it on the side of the road or in a parking lot.
    its a 24ft with a 2ft v nose, and im pulling with a 2007 1/2 ton chevy. i have load lever hitch and helper bags in the truck if i end up needing them also
  • ChamplinGT
    • May 2010
    • 16
    how far are you going?
      st paul to brainard
      • taank
        • 10278
        st paul to brainard
        i would still park it conventionally. you want and need tonque weight to elimnate death wobble. if i can pull my 4500 lb buick with an explorer you should be ok.
        Jake H.
        • ChamplinGT
          • May 2010
          • 16
          I personally would back it in and try that, it sounds like otherwise there would be a lot of tongue weight but you may need to experiment the first time and see what the truck likes and can handle. sounds like you need a 3/4 or 1 ton truck...lol. Good luck and drive safe. sounds like you'll have plenty of tongue weight with all the gear and the wheeler.
          • taank
            • 10278
            i would probally take a test run and adjust accordingly
            Jake H.
              thats why i figured id ask if anyones tried it
                yeah im going to buy a new 3/4ton dizzle this winter i think.
                maybe ill try it and see how nose heavy it is compared to with just the gear in the front. should be able to mesure squat vs angle to see.
                • taank
                  • 10278
                  i once saw a guy pulling a camper who had a go cart an four wheeler loaded on the back, he swayed for a bout a mile uncontrollably and the rolled it several times. was scary being the guy right behind him
                  Jake H.
                    i once seen a 5th wheel on the back of an s10 going south on 35
                    • D3thM3tal
                      IT Pro / Mechanic
                      • 3665
                      Where is the car going to sit compared to the axles? How far the weight leverages off the axles will determine where you want the load.
                      I bleed blue
                        Car should sit right over the axel
                        • Dustball
                          My title here
                          • 3251
                          Back it in.
                          Unless yours is a gooseneck, there aren't very many ball mounts that can handle 1500+ lbs of tongue weight plus you'll be driving with your nose in the air.
                          I've towed pickup trucks backed in on my 18 foot trailer and it tows just fine.
                          • Turbo302
                            • 1528
                            Pull it in forward first. You will be fine and would rather have more tounge weight/drop than death wobble at highway speeds by putting too much weight rearward.
                            I put alot of weight on the front of my trailer and is rock solid even at 90mph and windy...I do have a 3/4 ton so that helps. Why not put the 4 wheeler in last/back?
                            1988 5.0 Notchback
                            • bigblockpaul
                              i live my life a quarter mile
                              • 4137
                              pull car in just back as far back so door closes and you should be fine.air up the bags so front tires get good tread pattern.see you there..
