Anyone know where to get smaller versions of these?
  • Odrapnew
    Everyone likes being blown.
    • 2880
    Free Shipping - Dorman Oil Pan Drain Plugs with qualifying orders of $109. Shop Oil Pan Drain Plugs at Summit Racing.
    I've tried McMaster, Fastenal, etc. We are looking for an M8 size and the smallest I've found is M12.
  • siberianmist
    • 2681
    seven corners on west 7th always has shit like that when i cant find it anywhere else
    • 5.0stang85
      Hater's be hatin'
      • 7065
      Originally posted by Odrapnew View Post
      http://www.summitracing.com/parts/RNB-65267/?rtype=10
      M8x??
      fastenal cant get a bolt then use a aluminum or brass crush ring??
      Cooter's Coatings
      Hudson WI
      • gutlas5
        "7718"
        • Dec 2005
        • 2656
        napa? oreillys? carquest?
        10.89@123
        • Odrapnew
          • 2880
          I'll have to check with seven corners.
          Can't use a crush ring because we are using it to seal against plastic. We've tried a bunch of different sealing type washers(and have more to test) and we figured we'd see if we can find anything like the above. And, the big kicker, whatever we do find can't dig into the plastic when torqued down(only 1" OD flat washers have passed that test, but they didn't seal).
          Most(if not all) oil drain plug bolts are M12 or larger.
          • allstock93gt
            does not visit often!
            • 1959
            coat the washer in liquid teflon tape and let dry. turns into a farely hard but not solid.
            • Dustball
              My title here
              • 3251
              Try a good Ace Hardware with a big hardware selection. I believe they have oil drain plugs in their hardware slide-out drawers.
              • Dustball
                My title here
                • 3251
                Motorcycle drain plug?
                Try a local bike shop.
                • Chrm97PI
                  268ponies with more onthe way
                  • 3413
                  i wonder if tranny pump bolts are close to the rigth size? they have a self sealing washer. i know they are long but cutem off it they work
                    Could try Fastenal?
                      menards, home depot. they are called pole barn screws, they have 1in rubber coated washers. most of them are sae thread though like 10-24 12-24 10-32... but im sure if you look they will have some china shit metric stuff.
                      • Odrapnew
                        • 2880
                        Thanks for the ideas. I'll have to check into them. I checked fastenal, but they didn't have what I was looking for. I saw those barn screws a few times, but didn't look into them since I thought they were all coarse thread self tapping. The thread has to be M8x1.25 thread pitch.
                        • merkerguitars
                          FML
                          • Jun 2007
                          • 665
                          Take a bolt, weld a washer onto it, then use a rubber washer?
