5.0 block
  • brobber01
    Nw Robberstanger
    • Jul 2007
    • 149
    5.0 block
    Are the mounting bosses on ford 5.0 blocks different on any years or should i be able to use any mounts to install in a mustang?Any benefit to using convertible mounts on a non convertible?
  • 289Notch
    Lowballer
    • 7340
    NO
    Mustangless!
    • Old Man
      Elder Statesman
      • 5711
      All 302 blocks mount the same. The convertible mounts are wrap around mounts (the steel wraps around the rubber) and are stronger.
      www.transport-graphics.com
      www.knowltonsthunderheads.com
      www.dukesraceshop.com
      www.meanstreetperformance.com
      www.fleetwoodcollision.com
      www.idealautoglass.net
        Originally posted by Old Man View Post
        All 302 blocks mount the same. The convertible mounts are rape around mounts (the steel rapes around the rubber) and are stronger.
        Rape?
          did you mean wrap?
          • mark_eych
            • 1442
            Since you are talking 5.0 they will be the same. If you are putting a 5.0 in say a 1965 Mustang you will find the old block mounts are about 1" shorter. I am not sure what year it changed but my 1966 289 block has the narrower mounts.
            • 5.0stang85
              Hater's be hatin'
              • 7065
              not to mention whenever they did away with the 5 bolt bell housing/ block(not that that has anything to do with mounts but..)
              Cooter's Coatings
              Hudson WI
