wierd sputter
  • horseplay2
    • 125
    wierd sputter
    I was leaving the gas station with my 90 notch, went to hammer on it and it started to sputter in 1st, and 2nd then was good in the other 3 gears. started going from a stop and the same thing happened???? wtf? car ran great before the fuel stop... help also, if you push in the clutch and rev it up, its fine
    1990 lx coupe, 331inch, E-85 conversion
    270 RWHP-320 RWTQ, comming soon, 86 4eye conversion
  • horseplay2
    • 125
    ANYONE??????
    • jdominick
      • 2255
      obviously load related, greatest load is from dig
      check usual suspects, plugs/wires/cap/rotor check for knock, then air/fuel side, filters, injectors, pump???
      • Outlaw86'd
        bite it you scum
        • 3301
        where did you buy gas?
        • horseplay2
          • 125
          I run E-85, but It was same place I buy from all the time in town where I live. I thought of that too. car sits and idles awesome, no miss, maybe just a bit of bad corn?
            I would say yes. Ethanol is soluble in water and will suck up moisture. If the batch has been sitting there for a long time it could have a very high water content and will not separate out. Old watery e85 burns like shit and would explain sudden symptoms.
            Drain that shit out and get fresh stuff, I would never recommend going back to that pump. I would also demand a refund if you put fresh e85 in the tank and it fixes the problem.
