4r70w vs 4r75e???
    4r70w vs 4r75e???
    So the 75e is tougher? correct? but id assume the 70w is cheaper and easier to rebuild? both same smoothness?
  • Chrm97PI
    268ponies with more onthe way
    • 3413
    same transmission, 4r75e has a stronger input shaft i believe
    • octanehuffer
      • 5265
      Wrong.
        can you explain then good sir
        • Fosters
          Typical white person
          • 16014
          Neither your yota or your hyundai have enough torque to break either, so why does it matter?
          W is wide ratio, E is electronic controls. 70 vs 75 is the torque rating (x10) of the input shaft. They do have the same gear ratios however, the W was to differentiate its ratios from the 4R55E and 4R44E. I don't believe the W has electronic controls though. There are 4R70E and 4R75W models out there too...
          • octanehuffer
            • 5265
            The W is only meant to describe wide ratio. It has nothing in common with the A4LD series of transmissions, or to tell them apart.
            The 4R75W has a different stator support, improved converter, the planetary gearset has a newly designed manufacturing process, sun shell and forward sun gear is different, the pump body has a new piston design, planetary ring gear has a OSS lugs, among other minor details.
            • Fosters
              • 16014
              • wiplash
                2014 TT/GT
                • 3479
                In newton*meters!
                -No one ever
                • mysticcobra
                  • Nov 2006
                  • 469
                  4r70 will hold up plenty of power as long as its built right. Lentech has one rated to over 1000hp.
