pushrod length question.
    ok im getting ready to order pushrods. I have 7.500 stock I measured what I need and it is 7.75 for a tight fit, not pressing in the lifter. I punched in my combo on summit.com and it came up with 7.894 seems about right for me, but if anyone has put systemax heads on a 351 or if you can tell me that 7.894 sounds like the right length for hydraulic lifter please chime in before I order these.
    they also recommend 7.794
      I am using pedistal rockers so it would be nice if someone can tell me what to get here...
      • KickAssFlash
        TCS AutoX Driver
        • 11568
        Why don't you just get an adjustable pushrod? Better to do it right the first time.
        • OffShore
          yes it floats
          • 9995
          did you watch the roll pattern on the valve stem head?
            yes.
              how do you think I got the 7.75 measurement. like I said that is uncompressed lifter. the lifter is not squeezing down. so the measurement is not perfect.
              • KickAssFlash
                TCS AutoX Driver
                • 11568
                I'm sorry, I only skimmed over your post and saw "what summit suggests."
                • Old Man
                  Elder Statesman
                  • 5711
                  Has the block been decked, the heads resurfaced? What head gasket are you using. You really need to measure and order what your engine needs not what some book or some site says.
                  Welcome to the world of custom shit, it never fits the way the book tells you it will.
                  www.transport-graphics.com
                  www.knowltonsthunderheads.com
                  www.dukesraceshop.com
                  www.meanstreetperformance.com
                  www.fleetwoodcollision.com
                  www.idealautoglass.net
                    come on old man, did you just skim through the post as well... this is no where near my first build this is just my first build with pedistal rockers I guess im not sure how perfect they need to be. I have assembled the engine the new cam is in with just oil on the 2 lobes I am measuring push rod length checker installed. everything is set now how much do I add for hydraulic lifters when the rockers are not adjustable.
                    • MINNESOTA 5.0
                      I FIX OTHER PEOPLES FUCK UPS
                      • 2852
                      you have to figure in head gasket thickness,lifter preload,ect to your final length
                      89' NOTCH- 327 TURBO, C4
                      • Old Man
                        Elder Statesman
                        • 5711
                        come on old man, did you just skim through the post as well... this is no where near my first build this is just my first build with pedestal rockers I guess im not sure how perfect they need to be. I have assembled the engine the new cam is in with just oil on the 2 lobes I am measuring push rod length checker installed. everything is set now how much do I add for hydraulic lifters when the rockers are not adjustable.
                        My point was for you to trust your measurement not some book. I did not mean to insult you with my response. If that were my intent it would not have been subtle.
                        The lifters should not be collapsed soak it in oil for a few days, use your light pressure test spring and measure it. As for the pedestal rocker part, they need to me close, you can adjust them with the pedestal spacers.
                        I have know people that have taken a lifter apart and shimmed the plunger to make it a solid roller just for measuring.
                          this is what I want,need to know. the heads are on the heads gaskets are installed. the lifters are not bleeding down so I cant get a proper preload. any idea how much to add, to reach the lifter centerline.
                          see heads on
                          • MINNESOTA 5.0
                            • 2852
                            .020-.060 preload
                              .020-.060 preload
                              thanks steve thats what I need to know.
