96 mustang gt few questions
  • jp67stang
    bet ya cant do it like me
    • 1820
    Few quick questions all are about my 96 gt
    1. First can I just order a normal crank pulley bolt being that I have the steeda under drive pulleys, had a timing adjuster on it and want to take it off and I do not know if steeda uses a different bolt then the factory bolt.
    2. I need a manual transmission bell housing to block bolt went to ford and they told me they cant get them. Might of just been the retards their but anyone have one or 2 of them or know where to get them.
    3. Any one that did the pi conversion on a 98 and newer gt have you found that you needed to add a high torque starter. Don’t know if mine is going out or if it just wont keep up
    4. Last any looking to get a set of clear smoked headlights who makes a good set know some people have had problems with rubber coming off or just don’t fit right.
    Looking to order parts tonight so i can have my car out this week so let me know and thanks.
    mustangs are for fags
  • 5.0stang85
    Hater's be hatin'
    • 7065
    if no one local has a bellhousing bolt try fastnal i went there for a 3.8l bell housing to engine bolt... $8 and got 2 extra spares to boot
    Cooter's Coatings
    Hudson WI
      2. You can get the bolts at just about any hardware store.
      3. Your starter must be going out, because a normal starter should turn that thing over fine.
      • jp67stang
        • 1820
        i figured i would probley have to do this.
        • 5.0stang85
          Hater's be hatin'
          • 7065
          fastnal is the only place you can get them that i know of i tried everywhere with fastnal being the last place and they got them..
          Cooter's Coatings
          Hudson WI
          • SDK
            #1McMoppoFan
            • 12342
            Fleet farm has standard bolts that big
            • jp67stang
              • 1820
              found the bolt so im good on that now
              • Chrm97PI
                268ponies with more onthe way
                • 3413
                headlights on ebay, run ya around 60-70$ and will last a few years before replacement again is required.
                eagle eye brand light are pretty good
                • Hack
                  • 1415
                  Regarding the starter: make sure you have it tested before you just go out and replace it. Odds are you have a poor ground connection and the starter is perfect.
                  2017 Mustang GT PP
                  1986 Porsche 944
                  • 98Julik
                    • Mar 2007
                    • 2614
                    I did the pi swap on my old car and the starter worked the same... its not much of a increase in compression...
                    It's like watching a fat girl in stretch pants and a thong dancing. Sooner or later, something is going to happen, it might not be pretty, but you can't help watching
                    • 98RioRedGT
                      • 1966
                      the crank bolt is a torque to yeild bolt. get a new one from Ford.
                      -1969 Mach1 428 SCJ project
                      • jp67stang
                        • 1820
                        i know that but ive aways had a timing adj and lost the bolt that came with the steeda underdrives just wondering if its the same as a factory bolt. either way i already ordered a factory bolt to replace it.
