!!HELP!! drive train vibration.
  • merkurmike
    mare-coor
    • Apr 2008
    • 56
    i have a 91 stang 5.0 5speed. has the normal bolt ons (cold air, intake, headers, and throttle body). it has a vibration coming from the drive train. it starts when the car is going 70+mph. engine rpms dont change the vibration. same with pressing the brakes/clutch. woundering if anyone can help pinpiont the problem. and or has had this problem before.
  • DNeinstadt
    Administrator
    • 12578
    Tires.
    I would get to 70 and shut off the motor in neutral, still hear the noise? If so, have tires balanced, you may have lost a wheel weight.
    Go to Norm's tire!
    Dan
    • Odrapnew
      Everyone likes being blown.
      • 2880
      U-joints?
      How fast is the vibration? Is it more of a buzzing speed(like a sub woofer), or a shake(like a wheel weight)?
      • merkurmike
        mare-coor
        • Apr 2008
        • 56
        no noise just vibration. tires were just put on so dont think its that. i have heard of people having odd vibrations and putting an after market drive shaft on and taking care of it.
        • allstock93gt
          does not visit often!
          • 1959
          if the car has been lowered you may need to adjust pinion angle to fix this concern.
          • merkurmike
            mare-coor
            • Apr 2008
            • 56
            shaking. but it feels like its coming from the center of the car. you can feel it in the shifter. . o ya the trans was rebuilt about a year ago. so not that.its got me stumped
            • merkurmike
              mare-coor
              • Apr 2008
              • 56
              stock hight springs. no gears. good shocks.
                I second u joints
                • allstock93gt
                  • 1959
                  see if you can borrow a different drive shaft and just swap it. unless you find you have a bad u-joint.
                  • DNeinstadt
                    Administrator
                    • 12578
                    If you didn't have vibration before and you just put on new tires, I'd start there...
                    • Fosters
                      Typical white person
                      • 16014
                      This. I had a messed up driveshaft do that, only mine did it from 85mph on up.
                      • 289Notch
                        Lowballer
                        • 7340
                        wanna buy an aluminum driveshaft?
                        Mustangless!
                        • Killer Capri
                          Bumpin it up to 10L
                          • 4968
                          its junk. give it to me.
                          after youve lived though mine, hell is just a summer home.
                          • 289Notch
                            Lowballer
                            • 7340
                            I throw the stock ones in the scrap pile. I may have one though.
                            Mustangless!
                            • merkurmike
                              mare-coor
                              • Apr 2008
                              • 56
                              just started and have had the tire for about 3 months.
