Stock Fox accesories help needed.
  • 289Notch
    Lowballer
    • 7340
    Hello fine gentlemen. I am in need of help.
    I am attempting to put back together a fox mustang I bought in pieces. my other car/s are far from stock (v-belts, chevy alt, elec pumps). I am up to the front accessories. This car has a stock water pump, Power steering, and alternator. No smog or AC.
    I have a whole pile of parts in the corner. What would help me is if somebody near Forest lake had a stock fox or if somebody could post accessory pics of thier stock car or car with a similar configuration to mine.
    Mustangless!
    what specific info are you looking for?
      It can only really go together one way. There is a big aluminum bracket that goes on the passenger side head which holds the alternator and tensioner. The Power steering goes on the driver side, again mounting to the front of the head.
      • 289Notch
        Lowballer
        • 7340
        I have a whole pile of parts in the corner and I don't know if I even have all the brackets. basically I need to bolt the tensioner, alternator and P/S pump onto the motor. If I had another car or a picture to reference it would help. It's been quite a few years since I messed with a stock setup on a ford.
        Mustangless!
        • 87wheels up
          go for $broke$
          • Jul 2007
          • 249
          There is a factory 5.0 white convertible at John's auto. Just go look at it and remove what brackets you need. Cash for clunkers victom - fucking fed gov.
          • 289Notch
            Lowballer
            • 7340
            that's a good idea. I need a tensioner anyways and maybe brackets.
            Mustangless!
            • mark_eych
              • 1442
              I have a few pictures of early 80's set up so I would remember how some parts went on. Probably with AC. They will be over 2 meg and pm me an email address if you want them.
              Some of the Tbirds used the same brackets if you are looking.
              • Hack
                • 1415
                I have a complete 5.0 out of an '89 in my shop that I can take a photo of and email it to you if you need. Just PM me your email address.
                2017 Mustang GT PP
                1986 Porsche 944
                • 289Notch
                  Lowballer
                  • 7340
                  I'm now realizing the setup is not stock. There is a march alum bracket for the alternator that mounts to the head and 2 WP bolts. This relocates the alternator. I looked at a stock setup this morning and realized this. I need to check with march to see how this is designed to work. because this bracket won't work with the stock tensioner bracket.
                  Mustangless!
                  • 87wheels up
                    go for $broke$
                    • Jul 2007
                    • 249
                    You could make your own brackets:
                    I hand made the Alternator bracket and powersteering bracket. I bought the stupid idler pulley bracket even though a third grader could make it.
                    • 87wheels up
                      go for $broke$
                      • Jul 2007
                      • 249
                      FYI, the ribbed idler pulley itself is the idler pulley off of a 95 contour V6 (just happend to have it in the garage when I needed it)
                      • mark_eych
                        • 1442
                        Get a standard rotation water pump and a pulley from a late 80's to 91 crown vic and use your stock tensioner or get rid of the tensioner and use alternator brackets similar to v-belt style to get the adjustment. Go here for a picture. http://i6.photobucket.com/albums/y237/w2zero/fromps.jpg
                        I saw this at Fordmuscle
                        • 87wheels up
                          go for $broke$
                          • Jul 2007
                          • 249
                          Decent idea, although the wires are hideous looking coming from the alternator, thus why I flipped mine upside down. This is of course if one cares about how their engine looks.
                          • mark_eych
                            • 1442
                            Oh Yea? If you cared about how it looks you would wipe that spec of dust off the lower intake. Your set up does look good. I like how it is lower. Nice work.
                            • 289Notch
                              Lowballer
                              • 7340
                              starting to sort this out. I have the alt. bracket and tensioning rod shown here. I don't have anything except stock brackets for the PS pump.
                              Mustangless!
