Spark Plug Boot Popping off of plug?
    Mustangless
    • 18133
    1998 CSVT
    2004 3l Taurus DOHC Motor
    What would cause this?
    This is the 2nd Set of wires to do so.
    1st Setup
    Taylor Thundervolt 8.2MM Wires. APP104's
    2nd Setup
    Ford OEM 8MM Wires APP104's.
    In each case, both plugs and wires were replaced at the same time.
    Each time, the same cylinder boot plug is popping off. (#4)
    I Pulled the end through the plug, and closed it up a bit and pulled it back through hoping that will fix it.
    However, I was wondering if any one had any legitimate ideas on why this cylinder would be doing this.
    Just unlucky on the same plug wire between 2 sets????
  • OhMannClint
    Hated by the DEViDOs'
    • 6149
    try some gorilla glue
    Clint Ohmann
    651-399-9534
    High Pointe Realty
    ClintOhmann@gmail.com
    • taank
      • 10278
      put dielectric on the boot
      Jake H.
        Don't know what's causing it, but if you get desperate you can try tie wraps. I've seen it done before. It should take some force to pull them off IMO. Could try Scott or Magnacore wires.
        • MisterCMK
          Montgomery C. Meigs
          • 13910
          Is there a plug well seal that is bad causing the plug well to pressurize?
          LOOK HERE:
          Originally posted by Pony5.0
          • xjfish
            siiiiiiick!
            • 7357
            Bend your contact in with a pliers and zip-tie the wire before the boot if possible? No idea why this would be happening. I would make it stop and not worry about it.
            1987 Oldsmobile Cutlass Ciera
              Mustangless
              • 18133
              THanks for the ideas.
              I know i did not use Dielectric grease when installing (Just didint have any).
              I will pick some up and hit up the front bank of cylinders with it.
              I dont think it has popped off yet but i may try the zip tie at the top of the boot to keep it from moving off.
              • merkerguitars
                FML
                • Jun 2007
                • 665
                Leaky valve cover gasket causing crankcase pressure to push the plug boot up?
                PM me for all your Audi/VW needs.
                  Mustangless
                  • 18133
                  I dont think so. No oil in the Plug hole.
                  Also, It seemed to be popping with the cylinder fire.
                  • 5.0stang85
                    Hater's be hatin'
                    • 7065
                    beating on it to the point where the engine hits the hood? my GTI's No.2 spark plug wire would jump off after the engine would kit the hood
                    Cooter's Coatings
                    Hudson WI
                    • SDK
                      #1McMoppoFan
                      • 12342
                      You should always take your boots off so you don't get mud on the carpet.
                      • taank
                        • 10278
                        vw=fail
                        Jake H.
                        • 5.0stang85
                          Hater's be hatin'
                          • 7065
                          Originally posted by taank View Post
                          vw=fail
                          yes for the most part
                          Cooter's Coatings
                          Hudson WI
                          • taank
                            • 10278
                            no for all parts. i would rather take a shot in the mouth than be caught dead in a shitbox vw
                            Jake H.
                            • xjfish
                              siiiiiiick!
                              • 7357
                              Good point.
                              Joe: If the plug isn't loose, and doesn't have any sort of plow by through the plug itself or the head... Make it stop and call it good.
