rev limit 3000rpms... mustang
    cant figure this one out.... engine will not rev above 3000rpms.
    runs fine otherwise, seems to have plenty of power but wont rev above 3000rpms. tryed nuetral sensor conected, dissconected, grounded... tryed changing ignition coil... tryed changing ecu. compleatly stripped back harness and checked ever conection and every sensor and made sure everything was within spec. checked ecu for codes. non present.
    I was planing on swaping out the tfi next but thought I would ask if anyone has ever had a problem like this before...
    2.3l mustang swaped to 5.0l 86 block with dooe heads 1.7 rockers and 93ho cam. maf conversion. a9p ecu...
  • SmithEvo
    Poppin' VTAK yo!
    • Nov 2004
    • 25468
    Limp mode?
    Not at the table, Carlos.
    • xjfish
      siiiiiiick!
      • 7357
      Originally posted by bluchev
      BUDDERNIGGED?
      Bad TFI module would be my guess.
      1987 Oldsmobile Cutlass Ciera
        Try a different distributor/TFI...
          That's what we thought last night, but if its not the tfi, what else would cause a symptom like this?
            I would make sure the ECU harness has a good ground. There is a few grounds under the hood and then there is one right by where the harness mates to the actual ECU.
            If the guts inside the distributor are bad, then that can cause all kinds of issues.
            I just recently replaced my old dizzy with a brand new OEM Ford unit (Thanks Casey) and it seemed to fix the RPM issues I was having. Little different then what you are having but it fixed the issue.
              Plugged up fuel filter?
                New fuel filter and pump... I thought of ground checked over looked good added extra one just to be safe
                  Anyone up in the roseville area that may have a tfi and or dist that they don't need?
                  • Mullet Tuner
                    • 15906
                    MAF?
                    Originally posted by Gerald
                      Originally posted by black z View Post
                      MAF?
                      well the sensor is good... it ran fine on thundercoug at least... I could go back over and recheck the signal at ecu I guess... I will give that a check.
                      • SDK
                        #1McMoppoFan
                        • 12342
                        Just cause it's new doesn't mean it's good.
                          checked fuel pressure it is at 35psi at idle and 45psi with vac disconnected.
                          • POOPY PANTS FACE
                            EAT SLEEP POOP
                            • May 2007
                            • 12400
                            turn off ya 2 step.
                            TCS auto ftl
                            • KRYPTO
                              Our Fearless Leader
                              • Sep 2007
                              • 1632
                              Originally posted by sn95GT View Post
                              turn off ya 2 step.
                              but its wired to the trans brake
                              Im in Blaine letting some girl get 14" inches, i think she knows you....
                              If you think your shit is fast, you'd think my fucking turtle is a time machine.
                              Our Fearless Leader
