Fawking timing
  • SDK
    #1McMoppoFan
    • 12342
    Fawking timing
    I need to get the distributor into a 98 Tahoe. I know I need to get the compression stroke on #1. But there are not any timing marks I can see near the balancer. There is a mark on the balancer though. It is also I bitch to do alone. Fawk
  • Dustball
    My title here
    • 3251
    Posting on TCS about it will help.
      You didn't mark it?
      • gutlas5
        "7718"
        • Dec 2005
        • 2656
        whyd you take it out?
        10.89@123
        • xjfish
          siiiiiiick!
          • 7357
          To find #1 to top dead center just pull the plug and stick a piece of wire down the plug hole and turn the crank until it reaches its highest point or keep repositioning the dizzy until it fires and then set your base timing or pull a valve cover (easy enough on a 5.7) and use valve overlap to find TDC #1.
          1987 Oldsmobile Cutlass Ciera
          • SDK
            #1McMoppoFan
            • 12342
            Every one of your responses are bullshit. I did mark it and it looked right putting it in. But now it's all fucked up. I figured out that the timing mark is supposed to be at 12 oclock and the pointer needs to point at a mark in the dizzy when it is right.
              Ya if them fuckers are off one tooth it will set a check engine light
              • SDK
                #1McMoppoFan
                • 12342
                That must be after it starts
                  LOL sorry dude,if you were closer id come give ya a hand
                  • POOPY PANTS FACE
                    EAT SLEEP POOP
                    • May 2007
                    • 12400
                    it dont start?
                    TCS auto ftl
                    • xjfish
                      siiiiiiick!
                      • 7357
                      Turn the fucking dizzy to the next tooth over or back then FGT. I've done this before (fucked it up after I marked it somehow ) Also my response was legit.
                        why are you working on stuff? i thought you were a plumber? wtf.
                        dont mess with shit smarter than you, stick to clogged shitters.
                        • SDK
                          #1McMoppoFan
                          • 12342
                          HAHAHA Working on cars way more complicated but plumbers make way more money HAHHAHAHAHAHA
                          • iamtheshaner
                            • 3566
                            oil/grease/road grime < poop/scale/drain babies
