Camshaft Help
  • DaBus90
    mullet racer
    • 318
    Camshaft Help
    Alright I've got a BBC and I started to tear it down and checking out what parts were in it. I was checking over the camshaft and couldn't find any numbers on it that tell what company or any other specs. All thats on it is these markings/numbers: 1005R(on the dist gear end), EP2(cast into camshaft between dist gear and lobe), M(on the same end as the 1005R was stamped into but placed away from 1005R), D2(cast into camshaft between center cam bearing and lobe), and H2 and 09( cast into camshaft between fuel pump lobe and first lobe). Motor is a 454 cid
    any help appreciated
  • OhMannClint
    Hated by the DEViDOs'
    • 6149
    Sounds like a stock camshaft.
    I've always gone threw comp and they mark theres on the front but IDK about the others
    Clint Ohmann
    651-399-9534
    High Pointe Realty
    ClintOhmann@gmail.com
      non-roller?
      • FlamedROC
        Posts in WW threads only
        • Oct 2004
        • 225
        Speed-Pro Performance Chevy Big Block
        Price: $82.07
        Chevy 396-502 cid,
        RPM Range 1500-4000,
        Adv Dur 284 intake/284 exhaust,
        Dur @.050 208 intake/208 exhaust,
        Valve Lift 476 intake/476 exhaust,
        Lobe C/L 111.
        Seems a little small for a 454
        #14 until we meet to skate again
          junk ill allow you to scrap the engine at my house i guess
          • DaBus90
            mullet racer
            • 318
            thanks jason i searched online at all the camshaft makers and couldn't find anything and when search for a few of the number on google sealed power came up a few time but trying to search on their website no camshafts came up just a little intro to their camshaft line. and yeah the guy i bought the motor from said he put a mild rv cam in it but now that i see the specs time to go bigger.
            After looking at the specs and forgeting that the motor came with 1.7 full roller rockers don't think im going any bigger just check out different durations and intake/exhaust combos
            • FlamedROC
              • Oct 2004
              • 225
              Your welcome I actually found that info within 10 mins of looking. You just gotta know where to look I guess
